Step 1
Select locations for each of the Coby 5.1 speakers. Place the correct channel speakers in the best location possible. For example, a right-rear speaker should not be placed to the front left of the TV.
Step 2
Measure and cut lengths of speaker wire that run from each speaker to the Coby receiver. Include a few extra feet for mistakes. The speaker wire has two color wires, a red (power) and black (ground).
Step 3
Attach the red wire to the positive (+) terminal for each speaker. Attach the black wire to the ground (-) of each speaker.
Step 4
Make sure the receiver is unplugged. Examine the back of the receiver. There are speaker terminals for each of the speakers. Plug each speaker wire into its respective terminal. For example, plug the right-rear speaker into the right-rear terminal. Each terminal is clearly labeled.
Plug RCA cables into the appropriate input ports on the receiver. For example, there are RCA ports for the TV and DVD player. Plug the other ends of the RCA cables into their appropriate devices. For example, the DVD input on the receiver plugs into the audio output port on the DVD player. RCA audio cables are red and white, make sure to match the colors correctly: red with red, white with white.
Items you will need
- Speaker wire
- Wire stripper
- RCA cables
How would one do it like can u explain the hot leads to the switch and the monitor
