A roofing nail is designed to be easier to be removed, they have a smooth shank and wide head that hold down shingles. A siding nail has a ring shank. A roofing nailer is used to quickly pin down shingles across a roof, the depth at which they are drive in is generally shallower than a siding nail.
You can read a little more about roofing nailers here Best Roofing Nailer Shooting From the Hip Woodworking Tool Guide.
Hello Friend,
Here is a picture of shingles just to see if those itchy spots on your body can be shingles.
One of the distinguishing hallmark of shingles is that it has the pattern of following a line covered on your body by its accompanying spinal nerve. Oh shingles, how clever of you to have a pathway!
Now given the nature of vaccinations, I believe if people had any idea of what was being injecting into those immunizations they would be mortified, after all that is one way to build your immunity by injecting yourself with the very thing you're building defenses against. There are other healthier, safer ways to build your immunity. Case in point, I am a TRUE believer that if our immune systems were strong enough in the first place there would be no need for vaccinations. Enclose is a referral link to help you with those shingles should that be it. Fast Shingles Cure The 1 Shingles Treatment Method Available
The virus is spread through direct contact with fluid from the rash blisters caused by shingles. A person with active shingles can spread the virus when the rash is in the blister-phase. A person is not infectious before the blisters appear. Once the rash has developed crusts, the person is no longer contagious.17 Sep 2014
Usually like a band of rash around your middle, iwill tell you a cure and medicine says there is none but get at least one ounce or two even better of echinacia tincture and take it all in one day, you can't od on it if that worries you.
It is very possible that you have Shingles. The virus that causes shingles produces a painful, burning line of blisters that follow a nerve in the body. Shingles is basically the adult version of chicken pox. If you have ever had chicken pox then your body contains the virus that causes shingles. There is treatment for this as well as a vaccination; however, you will need to see your doctor to receive the treatment.
Ash fault? I think you mean "asphalt" but that's OK. You haven't given enough information to solve the problem, but here's what you need to do.
You know the area of the roof is 300 square feet (sq ft). You should know the area of each asphalt shingle, although that's the information you didn't give. When you know that figure, the calculation is very simple:
number of shingles needed = area of roof / area of one shingle
I don't know if this is a class problem, or if you really have a roofing job. Don't forget that on a real roof, the shingles overlap. If you do the calculation, the number you get is right only if you lay the shingles edge-to-edge. A real-world roof would need probably twice that number. Shingles come packed in bundles, and they usually tell you the area they cover. (By the way, 100 square feet is termed a "square".)
