Question about Cooktops
The hob comes up with L on all 4 rings .I assume this is a safety device. how do i unlock please.
3 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Posted on Nov 06, 2009
ray gallant
  • 66486 Answers
SOURCE: How can I unlock safety key on the hob?
sorry to say but with no make /model how can we look for information .try
Posted on Aug 23, 2015
Aug 23, 2015 | Cooktops
I have just moved into a new apartment in France, and we have a 2 ring touch screen hob. There are no instructions or booklets but it says "Schott ceran brandt" on it. It works, as I've worked out how to...
i presume that you have a induction cook top. if so not all pots and pans will work on them. i have never had one but i do know this could be your type of problem. do some research on what pans to use on a induction stove.
Jul 02, 2017 | Cooktops
UNLOCK THE LOCK OF CHILDREN IN CERAMIC
Hi and welcome to FixYa,
I can not insert the symbols here to properly answer your question so, I found the manual and you can read the steps on page 9 here:
http://awadnahas.net/pdf/UserManual/bf7e9e9b-cc9e-46fc-94a7-5965a2d61b18.pdf
This is copy and paste from the manual and the symbols will not come out:
Switching off the child safety device
• Start the hob with ( ' ). Do not set the heat settings . Touch for (Up arrow) 4 seconds. The
symbol ( 0 ) comes on.
• Stop the hob with ( I )
The symbols I typed above are not 100% as they appear in the manual.
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | AEG HK955070CB 41 in. Electric Cooktop
Miele KM 342 - I have burner - will ignite when knob pushed in but once release knob flame goes out
Hi dear.According to you're explanation,there is flame failure safety device in each hob.Please check the hob,there is one ignition plug & one prob next to each other.Please clean them up with hard brush to get rid of the cleaning chemicals(Like: CIF)residue.It's a sensitive prob becareful when you do this.Please make sure it sees the flame.As long as it feels the heat it'll let hob to run.If that's not work,you may need to change it.Please do this if you know what you're doing,other wise call service department.I hope that helps.Thanks.
Aug 07, 2010 | Miele 36 in. KM342 Gas Cooktop
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
Jul 28, 2010 | Neff Cooktops
Hob problems
Take a closer look at the wiring diagram on the base or in the book.Check you have put in the relevant links.If not wired properly you may only get half the hob working.
Hope this helps.
May 19, 2010 | Smeg 28 in. P752 Electric Cooktop
Jun 18, 2009 | Cooktops
Gaggenau kg260 gas hob, ring not staying lit, possible thermo-couple gone, request replacement cost / parts please
Thats the Stainless Steel model KG260-234CA with SuperQuick electric and Safety Thermocouple ignition, I think they come in pairs RS and LS, for around $27.00 per Pair + tax and SH.
The best place to get them will be SEARS PARTS DIRECT on Line at: http://www.searspartsdirect.com/
Eddie Rentas
Tupper Lake NY.
Jun 25, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Bosch ceramic hob
hold down powerboot for 4 seconds to switch off child lock
May 30, 2008 | Bosch 24 in. PIE675T01E Electric Cooktop
Cooktops Logo
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
