Music Logo
angel jack Posted on Jan 04, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to avoid upsetting chord recognition in roland e-a7?
Rajamohan RM
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Expert 187 Answers
  • Posted on Jun 23, 2020
Rajamohan RM
Expert
Level 2:
Passionate:
Answers
187
Questions
0
Helped
56791
Points
471
Roland Cube 30 Bass Amp won't turn on?
1. Check the power cable and ensure it is securely connected to both the amp and the power outlet. 2. Check the fuse and replace it if needed. 3. Check the power switch and ensure it is in the correct position. 4. Check the battery (if applicable) and replace it if needed. 5. If the amp is still not turning on, contact Roland customer service for further assistance.
New strings on acoustic guitar need to reduce the squeaking
Finger noise, whether you like it or not, it's part of the guitar sound. How much or how little is present can be controlled by the player but it is pretty darn difficult to get rid of it altogether. Acoustic string noise, often referred to as finger squeak, is a byproduct sound that tends to occur while changing between chords and notes, and when moving your fretting hand up and down the neck. Some players value this noise as a natural sound that gives a live quality to recordings, while others want clean takes with zero squeak.
Find out where It squeaks most
The first, and most important technique is actually being aware that the finger noise is there. A lot of players have just turned out to that squeaky sound and think nothing of it. So, as a self-diagnosis, grab a recording device like your smartphone, and your guitar will work just fine. When you've recorded the song, playback and see if there are any patterns or any particular chord progressions where the noise is more noticeable.
Learn To Release Pressure Gently
Perhaps the simplest way to get around these string squeaks is simply to lift and shift. By lifting the left-hand finger you are avoiding the drag along the string. Once you have identified the problem progressions, practice playing through them, but slowly. Take your time, and after you have played the chord or note, lift your fretting fingers gently until there's no downward pressure on the string but your fingers are still in contact, this will help to avoid accidental open notes being played.
Practice contactless transition
After you have mastered the slow release of the fretting hand, the next step is to work on contactless transition. While you're practising, make this a slow and purposeful manoeuvre, in fact, think of it as 2 separate actions - lifting your fingers clear of the strings, then moving your hand to the next position. Be careful to lift your fingers directly off the strings in a nice smooth motion - if you make the action jerky, or you remove them at an angle, you may end up playing unintended pull-offs.
Move to the next chord
When your fingers are clear of the strings, move your hand to the next position while consciously avoiding contact with them. Once you're in the correct position, place your fingers directly down on the strings. This can take quite a lot of practice to avoid having to make small adjustments after touching down.
Start Using Pad
More of a noise reduction than noise cancellation, you can help string noise by shifting along the string with the soft pad of your finger rather than the callused tip. The tip of your finger is hard because you have been doing oh so many hours of practice, and that tough skin makes a loud noise on the string. If you try and slide the pad of your finger along the string you will notice that it is actually less noisy. So, if you can't avoid the slide along the string then rotate your finger a bit so that you can shift on the pad rather than the tip.
Moisturize Your Plans & Figures
This one is more so for your hands than your guitar, but failing all else, keeping your hands moisturised will make them softer and smoother, which in turn will reduce acoustic string noise as you transition between notes and chords.
Squeaking happens in every guitar a little less or more, but Make sure you use the best guitar parts which suits your style and body posture.
If you're just getting started in your guitar journey, it should be straightforward to get into the habit of consciously lifting your fingers between transitions, but, if you've been playing a while, it will definitely take a lot of practice to adjust your muscle memory. The key is to start slow, and make every move purposeful.
Dec 31, 2017 • The Music
ROLAND D-70 Super LA Synthesizer. I am looking for the schematics or service manual
You should ask Roland Service. Here is the link-
https://www.roland.com/us/company/contact_us/
Roland Company Contact Us Contact Us
Midi sound does't stop
I don't have any of that gear, but check that an option like "note on/off" is turned on in the MIDI setup menu on the Juno-D. Also check in Logic that it's midi is setup right. Logic could also be receiving sustain pedal MIDI info from the Juno. Anyway, that's all I got.
1helpful
Wisdom required
If you can find the C-below-middle-C ?
Put your small finger on C,
your next finger on the next white key: D,
your middle finger on the next white key: E
your index finger on the next white key: F
your thumb on the next white key: G
Lift your fingers away from D and F -- to keep this simple -- all we did was identify the D and E and F and G keys, relative to the C key.
Press C and E and G (small, middle, thumb)
to play a "major" chord in C.
Move your fingers "up":
C to D, E to F-sharp, G to A,
and play a "major" chord in D.
D to D-sharp, F-sharp to G, and A to A-sharp,
and play the chord in D-sharp (usually called 'E-flat').
D-sharp to F, G to A, and A-sharp to C,
and play the chord in F.
Move your fingers "up",
F to G, A to B, and C to D,
and play the chord in G.
Go back to the starting position (C-E-G),
and move "down": C to B-flat, E to D, and G to F,
and play the chord in B-flat.
So far, you have C-major, D-major, E-flat-major, F-major, G-major, and B-flat-major.
There are more chords, but most pop-music is in one of these keys.
Give it a try.
A lot of left-hand stuff is just the small-finger and thumb, omitting the middle finger, e.g., C&G,
to avoid a too "muddy" sound.
Or, "stretch" your hand: C-and-G-and-the-next-higher-C.
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
