SOURCE: how do i reset my tablet
Step 1. With your tablet turned off, press and hold the volume up (+) button. While holding the volume up (+) button, press the tablet's power button until you see the RCA logo with Nipper and Chipper on the screen. After a few seconds, the screen will change and you will see the Android bot on his back with a caution symbol above him.Step 2. Now you are going to press and hold the tablet's power button, and without releasing the power button press down on the volume up (+) button,Step 3. Use the tablet's volume up (+) and down (+) keys to navigate to and select the "wipe data/factory reset" option. To select this option, press the power button.Step 4. The tablet is going to ask you to confirm your selection. Use the tablet's volume up (+) and down (-) keys to navigate to and select "Yes - delete all user data." Once again, use the power button to select this option.Step 5. At the bottom of the next screen, you will see "Data wipe complete." Press the power button to restart the system.6. The system will begin to reboot and once again display the RCA logo with Nipper and Chipper. The next "Welcome" screen will prompt you to select your language of choice. Scroll through the options using your finger and press start when finished.
SOURCE: How Do I Get Past a Pattern Lock MID8024
SOURCE: Hi...my goibii 7inch tablet is locked with a
look for your tablet on the internet and find the lock overide sequence keys
SOURCE: how do i reset my hkc tablet model number p771a
This should do the trick,
1)Make sure the tablet is NOT connected to the charger
2) Power off the tablet by holding down the power button for about 10 seconds
3) Once it is off, hold down the HOME button and connect the charger while the button's being held down.
4) When you see the HKC logo come up, let go of the HOME button.
5) Eventually, you'll see an Android logo with a red exclamation mark. If you don't, repeat step 3-5.
6) If you do see the Android logo, hold down the POWER and HOME at the same time for one second and just let go of the HOME which should bring up a "Recovery mode" menu with blue letters. Make sure you let go of the POWER button as soon as you see the menu pop up, otherwise your tablet will just shut itself again.
7) Navigate to "wipe data/factory reset" using the HOME button and select with the POWER button.
8) Navigate to "Yes - delete all user data" and select it.
9) Once it's done, you should see the menu come up again. Navigate to "Wipe Cache" and press the POWER button
10) It should take you back to the recovery menu. Simply press the POWER button while highlighted on the "Reboot system now"
Dave
Hi Mercedes, you will have to perform a factory reset to take the tablet back to when new!
Power the Tablet down completely. Press and hold the Power and Volume up buttons until a recovery screen appears. You should be presented with a screen that will allow you to perform a Wipe Data Factory Reset. Perform the reset then restart the Tablet.
