No, the NS-55D510NA19 is not a smart TV. There is no wireless or wired network option built into this model. The specifications are available here: https://www.insigniaproducts.com/pdp/NS-55D510NA19/6172325 .
I hope this helps.
SOURCE: Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
SOURCE: Verizon fios remote cant be programmed to control insignia tv
Orion code 0490 solved it for me!
SOURCE: fasten 32'' insignia plasma model ns-pdp32-09 to wall mount
I think it is probably a metric bolt. Maybe a 10 or 12 MM. There aren't many if any consumer electronics manufactured in the US anymore, and most use metric screws and bolts. Check one of the bolts from that table stand to see what it is. That will tell you if it is metric or standard.
Best of luck.
SOURCE: I need a Power Supply For Insignia TV Model
You can order parts for your TV here. Select your exact model for available parts.
SOURCE: i have a insignia tv ns-ltdvd32-09 that will not turn on
Look at the power supply, see it you can actually see any damaged components first, check the main AC fuse, burnt parts, etc.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
