SOURCE: Black INk Problem
Actually, Kodak replaced the print head, the tray that the cartridges sit in. All is okay.
SOURCE: Ink keeps leaking from the printer!
The problems you are experiencing are due to ink buildup in the ink absorbers that reside in the base of the printer. I'm surprised that you did not get a "ink absorber almost full" message. Unfortunately this occurs when more ink (heavy printing) goes in to this area than the ink absorbers can absorb and the ink starts to build up. An ink waste tube feeds in to the absorbers right in the front middle of the printer. When the ink begins to build up, it comes up through the paper platen there in the front causing the ink problems on the back of your paper.
The machine will need to be serviced. Canon suggest replacing all of the ink absorbers which is the easiest thing to do from a Tech perspective. The last machine I had in with this problem, I tore down machine and just rinsed all of the absorbers. You also have to rinse the underside of the paper platen.
Inkworks
866-381-0541
SOURCE: Kodak Printer Dock Paper Tray
ok - hubby did the same thing -duh ! but here is the phone number to call and the part number you need to give them - just verify it hasnt changed.
1800 431 7278 part number 5f0478
I was mad at him :)
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue
The Out of Paper
message appears on the computer and the product stops picking up or feeding paper.
Solution
Step one: Reset the product
Step two: Check the condition of the paper and reload it
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
NOTE:
Do not load too much paper in the product.
Step four: Clean the rollers
Step five: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
CauseAny of the following issues can cause the error message to appear:
SOURCE: The ip4500 will not print - says the paper output tray is open!
Just fixed this problem on mine. Need to remove the covers, watch these 2 vids to see how..
http://www.youtube.com/profile?user=martop49#p/u/1/iQdHDR6po80
Then
on the right side where the on switch is, near the hinge is a little
switch with 2 yellow wires, it's probably broke. Pull the 2 wires out
and solder or twist them together, then put everything back together.
It will now assume the door is always open. Jobs a good'n :)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
