Think Air FLOW. Air flow actually cools during normal use, so if flow is restricted, temps go beyond limits. Not what you want.
Here is an easy test: Pull dryer away enough to pull the exhaust hose off... Activate the dryer and form an opinion of the volume of air flow out of the back of the dryer.
Turn off, hook up the hose, Turn on again, go outside and likely you will find substantially lower air flow. I have seen installs that use a grill on the exit from the house. These clog up almost immediately.
Get the air flow working, your drying will be better.
My bet is something is clogged.
SOURCE: Whirlpool GEW9200LQ0 Gas Dryer
Andeb, 90% of the time long dry times are caused by blocked vents. If you are sure that this is not the case there are a couple of things to check. First check the sensor; press the more time button and less time button 4 times until 88 shows in the display.(more time,less time, more time, less time). Open the door and you will hear a beep and a see a code. On the inside just below the vent screen is the moisture sensor. Moisten your finger and lay it across the sensor strips covering both. If you hear a beep, the sensor is good. Sometimes they build up with fabric softner and need to be sanded lightly. Another issue might be the burner coils. Remove the bottom panel and check to see that the burner is igniting and remaining lit. Sometimes these coils become week and will not sustain the flame. I will attach a diagram, look at number 13 and 14 on the picture. These are the coils. Catriver..post back.
SOURCE: My Duet Whirlpool Dryer (had this #8519498) has burning smell
I am not the Dryer fixin' trade...but I have this dryer. To me, it sounds like it overheating or the heater unit has become lose from its hold rack. I would MOST definitely have a pro look at it and do NOT leave the dryer unattended...It may be a possible fire hazzard
Take Care
Wayne
SOURCE: Brand new Whirlpool Duet Sport gas dryer & burning plastic smell
I would consult the place of purchase. If they do not stand behind the product, then get the manufacturers support #. They will stand behind their product, especially if it is a possible fire hazard. THe smell you are smelling could be anything, but without being there and taking off the cover and doing a visual check. it's hard to dianose. It is possible that something that is plastic has fallen out of a pocket and gotten inside the unit while it was drying clothes and fallen onto the igniter housing.
SOURCE: clicking noise behind right side second row seat
I had the same problem. There are two regulators and the one that determines air direction is broken. The door inside is hung up and it strips the gears in the regulator. You can leave all the seats in the car but you have to remove several panels on the inside to get to the regulator. Many or them pry off. This can be risky if you are not careful and you may decide you don't want to risk it. Others need bolts removed (around the seatbelts) to remove. If you get to that point you will find two regulators that are white in color. They are anchored by 4 screws (i think) and come right out. Determine you have the proper one by toggling the face/floor button. You can follow the noise. The real problem here is with the door that hangs up. Mine hung up because the whole assembly was anchored against a big wiring harness on the back side that cracked the whole casing. Bad engineering. You may have to remove some sharp cracked pieces so the door moves easily. Problem is that you now will have a hole in your AC/Heating unit. You can replace that as well (expensive) or seal it some other way. By the new regulator from Ford and reassemble and you're done. If you are handy it should take you a couple of hours. My bro had the same problem on his Explorer and we fixed it much quicker the second time around. If you are not handy, you might want to reconsider.
SOURCE: GE gas dryer gets hot but doesn't dry clothes like it used to
rule number one take everything off of it and never store clothes or anything that can insulate the top it overheats them. It kind of fools all your sensors when you store stuff on top
