SOURCE: My Gateway m275 tablet will not charge or power up even with it plugged in
At least a 50% chance the power pin inside the computer has been damaged. Taking apart a laptop and getting it back together correctly is a tough job . . . .The part (the power pin) is not that expensive ($ 5-10) but the labor is expensive. If you don;t feel up to the task, have it fixed by a professional and after it''s fixed get a CRD (Cable Retention Device) to keep from damaging the pin a second time.
SOURCE: Power port on le1600 does not charge batteries.
We contacted Motion about an issue with our docking station because our power & USB ports stopped working, or worked only intermittently. We were instructed to remove the front cover from the docking station to check the connection of the cables. We found that the cable had completely disconnected (it had evidently pulled loose from tilting the dock up and down). Once the cable was reattached, and the cover reassembled, viola! Success!
SOURCE: Wont charge or keep a charge
First off, a google search will show you several companies out there that will replace the cells in your existing battery for around $70. Not bad. However, you mentioned that positioning of the plug can get it to work. The solder joints can become broken from the board, and the small plug in jack will get loose after a year or two of plugging in to it.
You can get a replacement plug at fry's electronics, or many online stores. If you need a service manual, or driver disk set, you can get them at mpcdrivers.com
SOURCE: My Dell Streak 7 Tablet will not charge. When the
I can't charge my sell streak 7 (no orange and green color appear when plug in) moreover the unit can't turn on also.
I tyr hard rest also but no response at all
would you please suggest me how to do it
SOURCE: my mid tablet will not charge
your charger probably died. go out and by a new one and see if that fixes your issue.
