Hi Alfonse-
I found this link regarding your Merits S2454 power scooter.
http://www.merits.com.tw/english/products/detail-01.php?pid=19
Click on "Supporting Doc". Click on "S2454/2354 Owners Manual".
On page 15, it states that 9 flashes means "Other internal error".
At the bottom of the homepage for Merits power scooters, there is a number to contact for further help.
Hope this helps.
SOURCE: POWER LIGHT BLINKS 5 TIMES
That's the LA-3 LCD projection unit. 5 blinks on that model means a lamp driver error. You would need the service manual to diagnose exactly whats wrong with the system. I have included a link where you can get the entire 121 page service manual for your set if you would like it. It cost 15.99 and they will email it to you and provide free support to help you diagnose it. Here is the link if you would like the service manual.
http://servicemanuals.vstore.ca/
SOURCE: STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
SOURCE: red power light blinks 9 times
Either a missing cable or you shorted the chips when you soldered them back into the TV.
SOURCE: the tv wont turn on. the red light blinks 9 times.
There is a problem with one or two of the diodes on the G board.
Zero Crossing Detector 9 times 9:0 or 9:1
Probable cause • D6116 or D6301 is open (G Board)
symptom • No picture
I hope this helps and good luck!
