Exercise & Fitness Logo
J
Joyce westmacott Posted on Jan 09, 2020
Login to fitbit - Exercise & Fitness
TheodoreLTabor
Level 1:
  • Contributor 4 Answers
  • Posted on Jan 09, 2020
TheodoreLTabor
Contributor
Level 1:
Answers
Questions
0
Helped
799
Points
15
Start working at home with Google! Just work for few hours and have more time with friends and family. I earn up to $4500 per week. It's a great work at home opportunity. I can't believe how easy it was once I tried it out..... HERE?? www.bayusd11.com
I just received a Fitbit Inspire - Do I have to have a Cell phone to use it? Is there a manual to use it?
No, you do not necessarily need a cell phone to use a Fitbit Inspire. While syncing the Fitbit with a smartphone can enhance its functionality by allowing you to receive notifications and track your data more comprehensively, you can still use the Fitbit Inspire without a smartphone.
To set up and use your Fitbit Inspire, you can follow these general steps:
  1. Charge your Fitbit: Plug your charging cable into a USB port or wall adapter and connect it to the charging port on the back of your Fitbit Inspire. Charge it fully before you start using it.
  2. Create a Fitbit account: If you don't have one, you will need to create a Fitbit account. You can do this on the Fitbit website or through the Fitbit app on a smartphone or tablet.
  3. Set up your Fitbit: Follow the on-screen instructions on your Fitbit device or the Fitbit app to set up your device. This typically involves connecting your Fitbit to your Fitbit account.
  4. Wear your Fitbit: Put on your Fitbit Inspire and start tracking your activity, sleep, and other metrics.
  5. Sync with your phone or computer (optional): If you have a smartphone or a computer with Bluetooth capabilities, you can sync your Fitbit data with the Fitbit app or Fitbit website to see your stats, set goals, and track your progress more comprehensively.
Jun 20, 2019 • Cell Phones
You have the wrong email address for my Fitbit how do I change it
FIXYA unpaid volunteer service is not connected to Fitbit.
Unpaid volunteers answer questions through the internet.
Fitbit has a website, and you should contact them to change the email address.
You can use http://www.google.com to search for other Fitbit web sites.
https://www.fitbit.com/login?redirect=https%3A%2F%2Fwww.fitbit.com%2Fuser%2Fprofile%2Fedit
1helpful
How do I put a profile picture on fitbit
1) Login to your account at www.fitbit.com
2) Click the little circle picture of the generic face toward the top right
3) Click 'Change profile pic' under the existing picture
Need help downloading a fitbit to my hp computer
  1. Go tohttp://www.fitbit.com/setup/and click theDownload Herebutton to download Fitbit Connect for your Force, Flex, One, or Zip tracker. If you have an Ultra, you should instead followthese steps.
  2. Once the download has completed, open the file and begin to follow the onscreen instructions.
    If you are on a Mac, open the dmg file. If it doesn't appear on your desktop, search for "Fitbit Connect" in Spotlight.
    If you are on a PC, run the .exe file from your download location. If it doesn't appear on your desktop, search for "Fitbit Connect" in the Start menu.
  3. Once the installation is complete, you will be presented with the Fitbit Connect Main Menu. SelectSet Up A New Fitbit Device.
  4. Account Setup:
    • SelectNew to Fitbitif you don't already have a Fitbit.com account.
    • SelectExisting Userto log in using your existing Fitbit.com account.
    • ou will be asked for a few details about yourself. This information improves the accuracy of your caloric burn and distance data. You can later adjust yourprivacy settingsto control which details are shared with others.
    • After filling out your personal information, you'll be asked which device you're setting up. Select the appropriate tracker to continue.
    • Plug the wireless USB sync dongle into your computer (this is the smaller USB device--not the charging cable), and bring your tracker near to it to begin pairing.
    • Tracker Pairing:
      • Force, One, or Zip: You will see a pairing number that appears on your tracker's display once your device has been located; enter this number on your computer.
      • Flex: Follow the onscreen instructions and rapidly tap the device when instructed, then confirm its vibration.
    • After clickingNext, your tracker will connect to your Fitbit.com account. This can take up to a minute.
    • Once your tracker has connected to Fitbit.com, you may be prompted to enter a greeting (depending on which tracker you have). This can be your name or any 8-character combination of letters or numbers.
    • When your tracker is linked with your Fitbit account, Fitbit Connect will notify you and present some basic instructions on using your device.
    • You can now log into your account dashboard to view your synced data.
      You will not need to repeat these steps once they have completed--you can simply login tohttp://fitbit.comto access your dashboard.Or Still having Problem Then follow Us For
      HP Support
Fitbit login
h e l p I bought a fitbit zip yesterday, I am unable to sync as it does not recognise my email address how do I redo the email address and password please [email protected]
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
