SOURCE: turntable technics sl-bd27
You have 4 wires coming from the needle pickup to the cables which connect to the amplifier/receiver. I would check the needle, the pickup unit, and the leads from the pickup to the cables. You can probably run a continuity test or ohm test for verification. If that checks, pickup and needle is your next step.
SOURCE: TECHNICS SL-B280 DUST COVER W/ HINGES
All parts are discontinued for this model. The SL1200MK2 dust cover will not fit this turntable. You can actually have a dust cover made rather simply and cheaply (depending on where you live). Just take the dimensions to a PLEXIGLASS or even a GLASS shop. You can even purchase the Plexiglass yourself, cut it, and glue it together. I would suggest getting it professionally done. You can use any high impact plexiglass. Get something that is resistant to scratches and discoloring.
- DJ PRO LAB
www.DJPROLAB.com
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
SOURCE: i PURCHASED A LIKE NEW TECHNICS SL BD27 TURNTABLE.
Yes you need a pre amp
It would also be the same if you connected it to a computer to record an LP to CD. Mine is a little different and has one already built in that I can switch in and out of line.
Try spend a little more if you can as many pre amps can introduce noise.
You may also want to check that the turntable is properly grounded to prevent noise too
Testimonial: "VERY FAST RESPONSE. THANKS"
SOURCE: Technics SL-J1 turntable drive belt
Hello Cliff,
You will need 2 belts, if the turntable belt is gone the other is not far behind . One for the turntable size 23.6 inch by .188 and one for the tracking motor that is in the top cover part, is a 3.0 inch by .046 belt. best place to get them is at kenselectronics.com part numbers 1407-201 and AV-SBS3.0 if you have been checking around you will see other sizes, I have a SL-J1 and have used these and they work perfectly.
Tony
