Electrical Supplies Logo
Isabella Tabuteau Posted on Jan 10, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
277 less than m is the same as 57? - Electrical Supplies
CJ Rock
Level 3:
  • Electrical S... Master 4,429 Answers
  • Posted on Jan 10, 2020
CJ Rock
Level 3:
Answers
4429
Questions
0
Helped
1645183
Points
15024
277 - m = 57
add m to both sides and solve
My Panasonic microwave model NN-SD-277 turns on but quits immediately - less than one second. Any thoughts on what it might be?
No one can tell you without looking at it. You need to ask yourself how old is, what did you pay for item what does a new similar model cost, You can look at other brands = Ask yourself what do you cook in it, do you need all the features s and the size, Personally i would replace it.
Error code 062-277 I need to solve the error how can do it
https://printcopy.info/?l=en&mod=erc&brand=Xerox&model=WorkCentre%205021&code=062-277
Xerox WorkCentre 5021 Error Codes
Code
062-277
Description
DADF Communication Fail Transmission cannot be established between the ESS/MCU PWB and the DADF PWB.
Remedy
1. Turn the power OFF and ON. 2. Turn OFF the power and check the connections between the ESS/MCU PWB J421 and the DADF PWB J751, J752 for open circuits, short circuits, and poor contacts. 3. If no problem is found, replace the following parts in sequence: • DADF PWB (PL 56.2) • ESS/MCU PWB (PL 18.1)
Winsheild wiper will not work
The wiper control module is probably at fault ,without test that is just a guess . The wiper/washer switch is a input to the wiper control module. Do you know anything about automotive electronics an electrical systems ?
  • The Wipers are Inoperative
  • Fuse.
  • Wiper motor.
  • Multi-function switch.
  • Circuitry.
  • Wiper control module.
  • GO to Pinpoint Test B .
Voltage drop testing the power an ground circuits for the wiper control module would be a good place to start . Do you know how to test electrical circuits with a volt meter ?
PINPOINT TEST B: THE WIPERS ARE INOPERATIVE CONDITIONS DETAILS/RESULTS/ACTIONS B1 CHECK FUSE JUNCTION PANEL FUSE 16 (30A)
Fuse 16 (30A)
  • Is the fuse OK?
Yes GO to B2 .
No REPLACE the fuse. TEST the system for normal operation. If the fuse fails again, CHECK for a short to ground. REPAIR as necessary. B2 CHECK FOR VOLTAGE TO THE WIPER CONTROL MODULE - CIRCUIT 65 (DG)
Wiper Control Module C294
Measure the voltage between wiper control module C294-2, circuit 65 (DG), and ground; and between wiper control module C294-11, circuit 65 (DG), and ground.
  • Is the voltage greater than 10 volts?
Yes GO to B3 .
No REPAIR circuit 65 (DG). TEST the system for normal operation. B3 CHECK CIRCUIT 57 (BK) FOR OPEN Measure the resistance between wiper control module C294-3, circuit 57 (BK), and ground; and between wiper control module C294-5, circuit 57 (BK), and ground.
  • Are the resistances less than 5 ohms?
Yes GO to B4 .
No REPAIR circuit 57 (BK). TEST the system for normal operation. B4 CHECK THE MULTI-FUNCTION SWITCH
Multi-Function Switch
Check the multi-function switch; refer to Section 211-05 .
  • Is the multi-function switch OK?
Yes GO to B5 .
No REPLACE the multi-function switch; REFER to Section 211-05 . TEST the system for normal operation. B5 CHECK CIRCUIT 993 (BR/W) FOR OPEN Measure the resistance between multi-function switch C269-4, circuit 993 (BR/W), and wiper control module C294-7, circuit 993 (BR/W).
  • Is the resistance less than 5 ohms?
Yes GO to B6 .
No REPAIR circuit 993 (BR/W). TEST the system for normal operation. B6 CHECK CIRCUIT 589 (O) FOR OPEN Measure the resistance between multi-function switch C269-1, circuit 589 (O), and wiper control module C294-1, circuit 589 (O).
Yes GO to B7 .
No REPAIR circuit 589 (O). TEST the system for normal operation. B7 CHECK THE WIPER CONTROL MODULE OUTPUT FOR VOLTAGE
Wiper Motor C152
Turn the multi-function switch to the HI position. Measure the voltage between wiper motor C152-4, circuit 57 (BK), and wiper motor C152-3, circuit 56 (DB/O).
Yes REPLACE the wiper motor; REFER to Motor-Windshield Wiper . TEST the system for normal operation.
No GO to B8 . B8 CHECK CIRCUIT 57 (BK) FOR OPEN Measure the resistance between wiper motor C152-4, circuit 57 (BK), and ground.
Yes REPLACE the wiper control module; REFER to Module-Windshield Wiper . TEST the system for normal operation.
Wiring a 3 wire photo electric cell
Open following link for photo-cell wiring illustrations:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#photo-eye
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electric circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
1helpful
The t104 comes new in box with timer jumpers to points 1 and 3 if i am wiring this to 277 i need to remove the jumper to post 3 and add a nuetral to the timer? correct?
277V instructions say:
Move small white motor wires to terminals A and 1
Connect 277 Neutral wire to terminal A
Connect 277 Hot to terminal 1
See illustration:
http://waterheatertimer.org/images/T-104-control-120V-Load-277-400.jpg
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
I have a intermatic model # T7402B that I'm getting ready to install and I'm a little confuse on how to install the power to the motor clock it shows a letter A is this for power supply and I assume that...
I'm not 100% familiar with 3 phase 277V.
T7402B manual shows clock is 208-277
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t7401b%20-%20english.ashx
T7402B > the manual does not specify terminal A or B.
On other Intermatic timers, Neutral goes to A and then Hot wire connects to B
Load terminals are wired separately and carry up to 40Amp
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
I need instructions for outdoor timer model TM-104 E227659
There are two different TM-104 timers that show in web search.
1) Buffalo TM-104 sports timer
I don't have information on Buffalo TM104, or a manual
2) Westek TM104 208 to 277-Volt 4HP timer is sold by Amazon:
http://www.amazon.com/Westek-TM104-277-Volt-Hardwire-Mechanical/dp/B002YGS6TU
I don't have a manual for Westek TM104 but can help you decipher your manual.
Also you can scan your manual into pdf format, post manual on your website for free, and then add a comment to this thread so other can enjoy your generosity.
There is one answer on fixya that says E227659 timer is Woods 59403
http://www.fixya.com/support/t6189563-need_instructions
Open following link to identify Woods timers.
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
Add a comment with more information about your timer, for example brand and appearance so fixya can narrow down correct answer for do-it-yourselfers seeking free information.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Find the three consecutive numbers? such that the smallest is 57 less than three times the largest
Let the three consecutive numbers be x, x+1, x+2.
Now, the smallest is 57 less than three times the largest...
=> x + 57 = 3(x + 2)
=> x + 57 = 3x + 6
=> 2x = 57 - 6
=> 2x = 51
=> x = 25.5
=> x, x+1, x+2 = 25.5, 26.5, 27.5
So, the three consecutive numbers are 25.5, 26.5, 27.5.
Microsoft streets and trips 2009 doesn't see my installed printers
Remove the program and re instsll it or use new one from torrents
http://torrent-finder.com/show.php?q=++Microsoft+streets+and+trips+&Browse=tabs&PageLoad=loadall&select=10&sids=1-23-314-36-2-323-4-3-6-84-35-10-344-316-30-249-24-28-361-15-334-18-276-296-29-37-60-17-343-58-306-325-337-327-14-57-12-44-330-252-253-48-359-305-56-108-313-54-51-273-351-72-78-79-68-80-73-264-258-332-55-303-350-245-307-340-41-353-341-21-5-26-31-9-77-251-226-342-64-65-246-16-256-338-333-348-331-97-279-105-87-319-320-89-93-99-100-104-124-287-299-298-109-262-268-113-114-347-293-274-119-263-322-349-315-140-282-267-110-292-244-49-133-122-125-257-277-144-284-103-137-311-312-149-152-123-132-143-142-291-283-358-356-85-141-121-101-288-147-324-52-153-154-280-150-317-346-269-345-336-339-329-120-354-357-155-156-157-321-355-360-162-163-166-160-165-167-169-
[email protected]
New Machine Control Electronics needed?
HUH????? just change interface(buttons and board ) have never took time to ck resistance.. front interface just tells machine control what to do
Top Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you an Electrical Supply Expert? Answer questions, earn points and help others
