An LRA rating isn't usually included on motor rating plates because it is of no practical help to the end user and because the locked rotor amps or starting surge is mostly a frighteningly high figure that also is of no practical help to the end user.
If the motor specified is the right motor for the job, the starting surge current exists for such a short time it is of negligible importance.
Mostly the only time surge current is a problem is when the supply is insufficient to efficiently supply the running motor when it is working.
Here in the UK there are a number of 3HP compressors that are inexpensive enough to attract buyers with only an ordinary 13 amp domestic supply. Mostly they are only just about usable if connected directly to a power outlet but they mostly will not work if even a good extension lead is used. As a general rule a 3HP compressor needs a 16 amp supply.
SOURCE: Need circuit board for Goodman GMNP-060-3 Rev B Furnace
Go to your nearest HVAC supply house. They should be able to get you it.
SOURCE: Equipment Available is 220v 50 hz 1ph. Supply 240v 60 hz 1ph
yes you can, just add a breaker to your box. the black wire goes to breaker and the white wire to ground. then you will have a 220v
SOURCE: what is LRA in compressor. whether LRA is used to
LRA is Lock rotor amps.
It is according to compressor capacity.
Call an electrician who knows the difference between Delta and Wye! Delta is Dangerous!
