SOURCE: radio shuts off at volume of 16 or more
Maybe a protection component cutting in.
If you have speakers that are too powerful for the radio it may shut down to protect the amplifier from overdriving the speakers. That produces too much heat in the amp chips/transistors and they either have a overload cut out protection circuit or they burn out.
Even if the speakers are the stock fitted ones the wattage could be bigger than the amp in the radio can handle.
There's probably no way of knowing how powerful the speakers in the truck are but you could try the radio with another set.
Max 50 Watts for that radio. If you don't have the manual for it, it's available here:
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
SOURCE: when volume is turned up the radio shuts off
Have you checked all of the connections on the speakers, stereo, etc. Being a marine CD player, the wires and connectors are exposed to more elements than a car CD unit. Check for corrosion and make sure that all the speakers are hooked up to the correct "+" and "-" terminals. Not sure if this will help, but thought I'd try. It does sound like a speaker connection problem.
SOURCE: Kenwood new sterio shuts off when turning up volume
You may have a short in a speaker. Check to see that the wire terminals on the speaker itself aren't touching any metal. Even 1 terminal touching metal will cause issues. Hope this helps.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
SOURCE: I have cobra 29 ltd has power going into radio but
remove the outer casing, there is a glass fuse..( 1.5 amp )....it has probably blown
