Have you tried going to Bing or Google (my preference) and typing in the Walker Mower Parts and let Google search for them. Have had tremendous results this way
Hello. From my research, the only thing that would change it from a sit-and-play to stand up walker would be to slide the foot rest out of the way. This video was helpful. It shows a baby using it standing up. Hope this helps.http://www.youtube.com/watch?v=CIRRYrlO4Lw&feature=related
Enjoy your little one while he/she is still little. Blessings. And if that doesn't work, here is the contact infor for Combi. Corporate Address Combi USA, Inc.3520 Westinghouse Blvd., Suite BCharlotte, NC 28273
At fist you have to check out where is the problem, the card, the card reader or the USB interface?
1. Change a USB interface, if there is some thing better?
2. Change a another card and see if the reader can read it?
3.Using another PC...
hi ; have you try to removed the battery uot and put it back 2;try to remove the cards out and in or put another one /because when you removed the battery its act as a reset. thats a suggestion
hope that will help you
ps it's look likes that is your memory card
SOLUTION 2 - Verify the reader's status under Device Manager.
STEP 1 - Connect the reader to the PC
NOTE: It is recommended that you plug your card reader to the back USB port on your PC to ensure that there is enough power from the USB port for the card reader to be detected properly.
STEP 2 - Check under Device Manager 1. Right-click My Computer. 2. Select Manage. 3. On the left pane, click Device Manager.
NOTE: The card reader will appear in two places: Disk Drives and Universal Serial Bus controls as USB Mass Storage. If there is a yellow exclamation point (!) or question mark (?) next to the device, try to refresh the drivers.
STEP 3 - Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action, and then click Scan for hardware changes.
STEP 4 - Verify if the reader is detected 1. Double-click My Computer. 2. Look for the card reader under Devices with removable storage.
SOLUTION 3 - Try other USB ports. A yellow exclamation point (!) under Device Manager usually means that the device is not receiving enough power. If the reader is not receiving ample amount of power from the USB port, it may not function properly.
ok ...I looked over and I did not sow any informations about what type of plug do ya actually need for his camera ...but my advice is a little much easier to follow... This camera supports a 1 G Sd card ( memory ) and if you do not have one ...just go for it ....it will cost ya something about 7 dollars on ebay ...and about 3 dollars to get a card reader ... if you already have it ..just get a card reader ...and ya will not need a driver cable or anything else anymore...and you can use it on other devices as well.. the price it will be about the same as a cable ...even less and the use will be much simple and for more purposes
REMOVE THE SCREW AT THE REAR WHERE THE TOY ASSEMBLY PIVOTS,AND LET THE KNOB FALL OUT. THEN PUSH THE ASSEMBLY INWARD AND LIFT IT SLIGHTLY TO CLEAR CENTER LATCH SLOT. THE RAIL WILL THEN CLEAR AND THE ASSEMBLY WILL LIFT UP. CHANGE THE BATTERY, REVERSE THE ABOVE TO RE-ASSEMBLE.
You need 1 mobile phones and a memory card reader.
1) Do _not_ turn off the mobile phone!
2) Remove the Memory Card from the locked phone and put it into a
memory card reader. Create
the directory E:\System\Recogs and copy thc-nokia-unlock.mdl into
this directory.
3) Remove the Memory Card and place it into the locked phone.
The THC-NOKIA-UNLOCK program should start after 120 seconds.
4) Remove the battery. Remove the MMC. Put the battery back and restart.
The Phone Lock has been reset to 12345
