Will your phone connect to internet through a router anyplace else? If it will then it's possible maybe that the settings in you router have limited how many devices can connect at one time. Maybe try disconnecting a couple of the other devices long enough to see if your phone will connect to the internet through your router then. If so you can Google the address for your router the connect VIA hard wire to your router go to it's page and maybe change a setting that will allow for more devices to connect through it! Thank you, hope this helps.
Testimonial: "The router allows more devices and some are turned off. I just received this phone and am trying to set it up so haven’t been anywhere else to try it. I really don’t think that will matter though."
SOURCE: Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
SOURCE: Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
SOURCE: connecting using wireless
I don't believe Zyxel supports only Zyxel products. Finally, after analyzing the problem between the zyxel and the router, I found a solution that worked and allowed me to network both wired and wireless connections here at home. Set your router to auto-dhcp settings. Clone the MAC address of your computer. After this is done, put OFF first the router but make sure that the cable from the router WAN port is attached to the modem already. Then, put ON the zyxel and wait until it is fully functioning (2 lighted LED lights) before you switch ON the modem. Let both units (router and zyxel modem)synchronize first about a minute or so. Then connect/put ON your computers.
I found the above procedure to do it step by step so as to avoid conflict signals during synchronization which seems to be causing the non-internet connection.
Hope this helps!
SOURCE: Not able to configure wifi router
im having trouble with wireless connection it says i have full signal but is not connected
SOURCE: No WIFI on D-link Router
If the wifi light is off its a sign that there's something wrong with it, so the first thing you can do here is to reset the router, To reset it press and hold the reset button of the router for 30 seconds and then power off the router for 10 seconds....
