Question about Exercise & Fitness
When I went to lower the deck of my Sole F80 treadmill, it suddenly slammed to the floor barely missing me. Is this something that can be fixed?
    Top Expert:
  • 11,405 Answers
Take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U can also get free manuals
Posted on Jan 11, 2020
Anonymous
SOURCE:
When i step with my right foot the left frnt wheel lifts off ground, how do i fix this?
My first thought is to adjust the leveler foot on the back right of the deck. If the lock nut is loose the foot may need to be screwed out so the deck is solid on all four points.
Jul 02, 2014 | RTO Sole F80 Treadmill
I have a sole f80 its about 3 years old it is giving me the ls1 ihave lub the belt, but i feel the motor may be bad i can stand on the belt 2mph and the motor stops it not slipping the belt as i have the...
1st most likely: walking belt and deck.
2nd most likely: motor control board
3rd most likely: drive Motor
4th most likely: no/off switch.
if you sole f80 is less than 5 years old you have parts warranty.
Jun 19, 2017 | Sole Fitness F80 Treadmill
How do i replace running belt
basically
Loosen old belt
take out rear roller
undo bolts for deck(both sides is easier to put belt on)
loosen front roller ( opposite side of pulley)
Slide belt on .
Reverse actions and put back together.
Tension belt correctly.
Or call a treadmill repairer
Dec 03, 2013 | RTO Sole F80 Treadmill
How to reset F80?
see the video attached.
Apr 01, 2013 | RTO Sole F80 Treadmill
My sole treadmil makes noise when changing levels
1) Lube the deck belt, very well, maybe you have WORN deck belt, time to replace, this happen because the lack of maintenance schedule.
2) LUBE the roller bearing TOO.
3) Measure the input voltage motor, if there are voltage , the motor NEED repair.
God bless you
Oct 14, 2012 | RTO Sole F80 Treadmill
My fans dont come on, on my brand new sole f80 treadmill
1( test the voltage to the terminal , if there are voltage the FAN is faulty, change it.
2( if there are NOT voltage to the terminal FAN, test the line why are NOT coming voltage, test some fuse, or c. breaker, tight any plug, connector, or loose wires.
3( Try again.
see the block di attached. and fix it.
God bless you
Oct 01, 2012 | Sole Fitness Sole F80 Treadmill 2011 Model...
My control panel on the Sole F80 Treadmill lights up but nothing I press works
adjust the REED SWITCH, see the diagram attached, clean it and tight the wires connector very well.
tight the ribbon cables insides from keypads +tight the wires connector from display board vs lower board and clean it.
God bless you
Jul 22, 2012 | RTO Sole F80 Treadmill
My Sole F80 deck bounces excessivly when not at an incline.
1) Lube the deck belt, this problem is lack of maintenance, maybe the deck belt is worn.
2) You must align the deck belt see the diagram
3) Lube the rollers bearing very well very important too
see the video: God bless you
May 15, 2012 | RTO Sole F80 Treadmill
E2 code on f80
CompartirFacebookTwitterGoogle+DeliciousDiggGoogle BookmarksMySpaceStumbleUponRedditMessengerVodpodYahoo BookmarksBeboMister-WongWordPressGoogle ReaderOrkutXINGEvernoteNetvibes ShareStrandsPosterousBusiness ExchangeArtoTipdSmakNewsPlurkAIMYahoo MessengerIdenti.caMozillacaBlogger PostTypePad PostBox.netNetlogTechnorati FavoritesCiteULikeJumptagsHemidemiFunPInstapaperPhoneFavsXerpiNetvouzWinkDiigoBibSonomyBlogMarksTailrankStartAidKledyKhabbrMeneameYoolinkBookmarks.frTechnotizieNewsVineMultiplyFriendFeedPlaxo PulsePingSquidooProtopage BookmarksBlinklistFavesYiGGWebnewsSegnaloPushaYouMobSlashdotFarkAllvoicesJamespotImera BrazilTwiddlaLinkaGoGounalogHuggDiglogNowPublicTumblrLiveJournalCurrentHelloTxtSpurlYampleOneviewLinkatopiaSimpyLinkedInBuddyMarksAsk.com MyStuffViadeoMapleWistsConnoteaBackflipMyLinkVaultSiteJotSphinnDZoneCare2 NewsHyvesSphere***** BrowserGabbrSymbaloo FeedsTagzaFolkdNewsTrustAmazon Wish ListPrintFriendlyRead It LaterTuentiEmailRediff MyPageGoogle GmailYahoo MailHotmailAOL MailAny email By Lockerz 1)faulty speed sensor or 2) the speed sensor is not plugged in properly 3) Need to adjust again face to face against motor magnet . 4)faulty motor Test without load measure 115vac. 5) control board or lower board test if 115 vac are coming to the board 6) See the transformer measure primary voltage and secondary 7) Test the power supply for +5Vdc 8) See if there are component burn. 9) Lubricate the Deck belt 10) Adjust the tension for Deck belt by 2-3" for lift .The error codes will differ between makes and models but could be e1-e2
See the block diagram for diagnostic and take your resultant.
Sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua
Dec 18, 2011 | RTO Sole F80 Treadmill
Error code of ls1 on sole f80 treadmill
John what are you talking about. All that's gonna do is give a LS error if you disconnect the motor.
Aug 22, 2010 | RTO Sole F80 Treadmill
Exercise & Fitness Logo
29 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
