SOURCE: hoover steamvac won't spray water on carpet.
Check the ank valve to make sure when you push it in that water is coming out. The reservior asm, (the tank bottom sits on this)is bad or the rod in the handle isn't pushing the reservior asm when you squeeze the trigger.
SOURCE: hoover f5520 steamvac duo upright wet washer
Your problem is inside the vacuum hose where they have installed a small coiled hose that carries water to the smaller power head for upholstery. After taking this apart I found the inner smaller coiled hose was broken at 2 different places. A very poor design and poor quality material. The hose looked like it was rotted. This could be from old detergent left in the line or maybe the wrong detergent. A job to get it apart but if you remove the three screws that hold the side plate over the electrical you can block that hose off and the machine will work on floors only as the water to the power head is terminated.
SOURCE: Why won't our Hoover Floor mate deliver water for cleaning?
After reading postings I created my own solution. I took a 1.5cm (approximate length) flush head finishing screw and screwed it into the button contact of the white memebrane and adjusted it to the necessary heigth to make the rod depress at the corrrect depth. My initial placement was too high and I had a continuos flow of water, but was able to fine tune. Also note the head of the screw I used was a similar circumference of the nob of the white membrane.
SOURCE: will not spray water
After the last use did you run a FULL tank of HOT water throught he machine to clear the lines and the pump? If not the soap has clogged one of the two. If it is the lines simply remove them (one at a time is less confusing) clear them and all is good. If it is the pump (white L shaped object back left corner of machine as you face it) you will have to go to a local vacuum repair shop and order the part.
SOURCE: Carpet steamer continually sprays water/cleaner. Can't stop it!
This is a solution for the Bissell Pro Heat, although it may apply to other Bissell steam cleaners as well. This is for the problem of the cleaning solution continually spraying without stop.
I found a quick and simple solution to this problem.
This problem occurs because the valve that allows the solution to flow gets "sticky" and will not close. The valve is engaged by the trigger mechanism in the handle. Squeezing the trigger pushes downward on the valve's plunger, but the spring in the valve that is meant to push the plunger back up to the closed position is not capable of doing so.
Here's the solution:
This valve is white and resides about half way down the vertical handle portion of the cleaner. To get to it, unscrew the 2 black screws that hold the top part of the handle to the bottom part. These are the same screws that you used for assembling the cleaner when you first bought it. Pull the top portion of the handle up and it should slide out.
Now, looking down into the handle body of the remaining portion of the handle, you'll see the top of the white valve. If you push down on the top of the valve (like the trigger mechanism in the top part of the handle you just removed does) it may go down some, but it probably won't go back up by itself like it should.
I found that lubricating this plunger with dish soap was the trick. If you can't get enough access to the valve to do this, you can remove the seven phillips head screws in the lower portion of the handle and pry it apart. I did this. I even took the valve out and put soap around the plunger and into the valve itself. I worked it up and down until it had a quick and positive open/close action.
Reassemble and you should be good to go. You'll notice that the trigger now has a more positive feel to it. I hope this helps.
