SOURCE: How accurate are the calorie counters on treadmills and cardio equipment?
Here's what the Sole exercise equipment makers say about calorie counters on exercise equipment. it's from their E-95 users manual: "Calorie readings on every piece of exercise equipment, whether it is in a gym or at home, are not accurate and tend to vary widely. They are meant only as a guide to monitor your progress from workout to workout. The only way to measure your calorie burn accurately is in a clinical setting connected to a host of machines. This is because every person is different and burns calories at a different rate. Some good news is that you will continue to burn calories at an accelerated rate for at least an hour after you have finished exercising!"
SOURCE: need instruction sheet or manual for cory everson
http://www.sony.nl/product/paw-minidisc---net-md-walkman/mz-n510/tab/manual here you finnd manual in difrend lang
SOURCE: how to assemble a gold gym millennia series highr...
Call Icon Fitness @1-800-999-3756 they be able to locate a manual for good luck!!
SOURCE: was given a Schwinn spin bike Model DX 900. Has
Sometimes taking them out looking at the Battery holder for corrosion first then check if the batteries are in the right way ( I've made that mistake ) Also the wire that leads down to the sensor and see if its adjusted correctly
SOURCE: how do you calibrate a york treadmill?
yes you must read the instruction manual for software calibration.
or open the hood motor, and read the instruction attached.
or you must call to York supply for customer service and ask them where is located in case that you will not find them.
God bless you
