My display has just started showing an extra bright band of 20 cm wide from top to bottom of the screen
    Top Expert:
  • Televison & ... Master
  • 30,805 Answers
On what I wonder ...........
Posted on Jan 12, 2020
Testimonial: "On a Samsung tv"
Anonymous
SOURCE:
Anonymous
  • 89 Answers
SOURCE: Purple band
It lloks like the video cable or inverter may be bad. Worst case scenario is the LCD may be bad. Try replacing cable or inverter first.
Posted on Jan 07, 2008
jason
  • 905 Answers
SOURCE: black band running from top to bottom of screen
this will need to go into the shop to get one of the video processing boards replaced that controls that part of the screen , this will happen when it gets to hot inside the set ,( thermal break down)
electech
Posted on Oct 31, 2008
taran_2005
taran_2005
  • 10515 Answers
SOURCE: broken horizontal stripes except for 6" band
there are two convergnece boards in this tv. one is called the convergence (DCU) the other is called the convergence amp board. this amp board has the (STK`S) on it and ids your problem. in most cases we repair this board.
good luck :)
let me know if you need more info?
Posted on Jan 11, 2009
Anonymous
  • 4 Answers
SOURCE: Magnavox 42MF7000/17 Green Stripes Pixel down section of display
Possible Defect in programing. Call Manufacturer for possible support in Updating Firmware.
Posted on Jan 18, 2009
Anonymous
SOURCE: 26PF9956/12
Take the back off the unit. There are 2 20 pin cables that go to a small board that sits on the right side (viewed from the rear) spray the back of the plugs with contact cleaner and wiggle these cables where they plug into the small board.
Posted on Jul 20, 2009
Why does my TV show discolored vertical bands and can I fix it at home?
The T-con board controls the picture elements on the screen. Usually replacing this board will solve the problem. If you can touch the screen and the lines disappear and later reappear, that says the screen itself is defective. The only fix is to replace the entire screen.
Oct 10, 2015 | Hisense F42K20EGB 42" LED 1080p 60Hz
White band from top yo bottom of screen
Good luck with this. If it is under warranty, Sharp will take forever to do anything about it. I had this issue and Sharp wanted pictures of the problem, Pictures of the serial and model number and the receipt. I sent it to them 6 months ago and never heard anything back. If it is not under warranty, this is a major repair and it may cost more than a new television.
Apr 11, 2014 | Sharp LC60E88UN 60 in. LCD TV
White vertical band in Cyan and Black
try to clean the laserwindows of the printer.
Mar 25, 2013 | Xerox Phaser 6125 Laser Printer
I have an Emerson Plasma TV (PL-P42W-10A) and it cuts off the top and bottom of the screen. It just started doing this. The only sizes that are available are 16:0 Zoom1, Zoom2, and 4:3. The Wide Fit and...
Our prolem is no matter how we adjust the screen when ever there message at the bottom of the screen this don't show up or is cut off. I get upset when I pay the amount for this 42" Plasma TV and watching the news there extra messages across the bottom of the screen espically when school closing due to weather. I've try to figure out using the instruction booklet with no results. Any ideas where the screen to where extra messages in lower screen can be seen to be read?
kimandtomaleexander@gmail.com
Oct 26, 2010 | Emerson EWL3706 37 in. LCD Television
Brownish band across top of screen
Please press the WIDE button on the remote repeatedly to remote the Bands. If the issue persists, you may need to change the Aspect ratio to 4:3 on the Video source that you have connected to the TV. Check the link for more info:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C308757&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=130649210&stateId=0%200%20130647809
Sep 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Band of virtually solid white lines (ca 7cm wide)
check on bios if still there then monitor needs repair.
Sep 15, 2009 | Dell E176FP 17" LCD Monitor
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
I have a Dell 17" LCD monitor with a horizontal band.
You would better served replacing monitor you can buy one for about $100-$120 dell if you lie has one for $99
Mar 01, 2018 | Dell Computers & Internet
Inch wide vertical white band on my Imac screen?
If the white band appears right from start up, the display needs to be replaced, if it comes on after it starts, it is most likely a software problem.
Feb 16, 2009 | Apple iMac G5 Desktop
Black band running from top to bottom of screen
electech
Oct 31, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
