Here are some videos that may help you
https://www.youtube.com/results?search_query=cleaning+head+on+Epson+WF-600
Regards
Geoff
SOURCE: magenta not printing
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
SOURCE: magenta and yellow wont print ,new
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
SOURCE: Epson workforce 600 prints with
new ink carts, cleaned heads, reloaded drivers ?
hardware issue, you already performed troubleshooting needed for this issue (try calling tech support and same steps will be provided)
better check your warranty or ask for repair options
SOURCE: I have epson wf 600.but the black &magenta ink is not printing
Hello
have you tried replacing the cartridges if you have then try cleaning the print heads as described here:
http://files.support.epson.com/htmldocs/wf600_/wf600_00ug/wwhelp/wwhimpl/common/html/wwhelp.htm?context=Epson&file=WF600.1.156.html
