SOURCE: fast battery drain
their was a deffect in the phone so plese check it to your near company authorized service center
SOURCE: Keeps Shutting OFF (battery shows fully charged)
Have you tried to update the phone's software/firmware? You should be able to get the update software from Sony Ericsson website and follow the instruction. Hope it helps.
SOURCE: battery drains very fast
First, before we proffer any solution, we need to know the problem.
Before the battery drains, does the phone gets hot in any way?
If your phone gets hot, then maybe the problem is from the phone board.
But if your phone does not gets hot before battery drains, then it is obvious that the fault is from your phone battery.
The solution therefore is for you to change your battery to an original one. The same problem might persist if you don't purchase a good battery, please take note.
I wish you the best.
SOURCE: battery problem for experia arc s
Batteries do not last forever, they often need to be changed, Looking at the specs of this phone the battery MaH is pretty low for the type of phone that it is. Android phones can drain batteries quite fast, and depending on how long you've owned the phone.
You can purchase a replacement battery, or.. An Extended battery can help keep your phone running for longer periods of time. (http://www.amazon.com/ericsson-Replacement-Lithium-Ion-Extended-Battery/dp/B005PFOGIW)
SOURCE: zte z990 phone keeps shutting itself off
Well, it really depends on many factors. I guess that you are using many apps at the same time (Background apps consume battery).
Another possibility is that your battery is asking for a retirement. Replace it and see if the problem persists. You may need to take it to the repairman.
