Question about Bosch Washing Machines
How do you make the water level higher on a Bosch 500 front loader
Anonymous
SOURCE:
Anonymous
SOURCE: bosch front loading washer nexxt
could be drain hose is not high enough. I had the same problem and when I raised the hose it worked fine.
Posted on Dec 04, 2008
Anonymous
SOURCE: e13 error code with my
I had an E-13 error code on my Bosch 500 series washer.  The drain pump  impeller was plugged.  Access the drain impeller at the bottom front right corner.  Just put a pen in the hole and turn the cover.  Then you need to manually drain the washer.  I used a shop vac by just turning the cap until it started to leak and vacuum the water as it comes out, this takes quite a while.  When you get it drained you can take the cap completely off.  When I did I found a wipe in the impeller.  I took it out and put it back together and the washer worked just as before.  Good Luck!!
Posted on Mar 24, 2009
evanusa
Evan Benson
  • 198 Answers
SOURCE: water wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Posted on May 31, 2009
Anonymous
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
Anonymous
  • 4 Answers
SOURCE: my bosch wfk2401 front loader is stuck on spin
Hi
There is a door bottom right of the system which has a screw out (by hand) plug.
Remove this and ensure there are no foreign objects such as coins, bobby pins etc stuck.
I have found this to be a problem with the Bosch systems and cost me $150 the first time.
Ensure you have some towels as when you open the plug, water will escape
Mark
I have a Bosch front loader washer. It has begun leaking water out of the bottom, and often will not run through a full cycle, but we sometimes get lucky. I tried it today and 5 mins into the cycle it...
You have to inspect water outlet from the drum. When it starts filling water, water leaking out at the same time. So computer sees, thet water level is not going up, so it stops. You should call service, or if you have someone, who ca open and see. Some times you can find it yourselves
Dec 02, 2017 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Error code E12 Bosch washing machine front loader
I have the Bosch Vision 500 Series with the E:12 error. My issue was the water inlet valve. When the washer was filling up very little water could be seen coming into the washer and if you just hit the button eventual you would get enough water usually three times during entire wash cycle. Replaced the water inlet valve myself in about 5 minutes very easy. YouTube videos show exactly how to do it. Now the water comes in almost covering half of the front window. Just finished first wash without and problems.
Apr 10, 2012 | Bosch Washing Machines
HI, I have a Bosch 500 series front loader 3 years old in daily use . My question is, approximately how long do the water hoses last and when should they be replaced? Hoping to hear from you soon...
the water hose will last for years how ever they may need to be removed from the washer and clean out the screens on the fill valves the main supply hoses do not wear out as far as i know.
Feb 12, 2011 | Bosch Washing Machines
Washer leaks when it isn't packed full of clothes.
check your door seal if leaking in the front if the back its probably one of the water lines leaking
Feb 24, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Is it getting enough water?
For front loaders, they usually have the level underneath the door, they use small amounts of water, but they spin so all the clothes do get
soaked with water.
Feb 05, 2010 | Samsung WF317AAG Front Load Washer / Dryer
Somehow, she added water to raise the amount of water in a bosch front end loader and it overflows when adgitating. how can I manually remove water?
take the drain hose at the back and lower it so its beneath the water level in the drum--the water should flow out--or else open the filter at the front--but thats a bit messy
Nov 16, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch front loader washing machine water pump?
Jul 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
500 WFMC3301 Bosch Front Loader
The door for this model of washing machine cannot be changed to open from the left.
Jul 07, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
How to increase water level in my frontload
The water level is not user adjustable but if there is a problem then the analog pressure switch should be changed.
Mar 09, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
Top Bosch Washing Machines Experts
Marvin
Marvin
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
