Question about Kenmore Sewing Machines
Where is the clutch on a kenmore model 1803 sewing machine. Not sure this is the problem. Hand wheel turns freely by hand, but when motor engages, the belt turns, but will not engage the hand wheel.
5 Suggested Answers
Page Gettman
  • 30 Answers
SOURCE: Hand wheel spins without moving the needle
I used to have an old Bernina that had an inner and outer hand wheel. Loosening the inner wheel disconnected the needle bar from the motor so you could wind the bobbin without running the needle up and down. It sounds to me like your machine has the same feature, but resistance on the needle makes the inner wheel loosen up. I don't know whether wrenching on it as tight as you can would be enough, or whether this is a symptom indicating that there is something loose internally in the connection between the inner and outer wheels. Good luck!
Posted on Jan 24, 2009
Anonymous
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
Anonymous
  • 96 Answers
SOURCE: Hand wheel wont turn on my Kenmore sewing machine
it sounds like the belt to turn the wheel broke
Posted on Dec 13, 2009
paj42
  • 1116 Answers
SOURCE: my kenmore sewing machine won't wind the bobbin
Not all models are the same.
You will have to refer to the manual to see what needs to be engaged or disengaged.
On some machines, this is loosening the center knob on the handwheel and moving the bobbin pin to the right or the winding knob to the left.
There are threading/bobbin winding guides sewusa.com where you may find your model or one that is similar.
Posted on Mar 21, 2010
ken dourof
  • 980 Answers
SOURCE: Toyota 2260 sewing machine. When I press the foot
Chances are you have a small piece of thread stuck in the raceway, turn the balance wheel bac kwards and you may free it off otherwise take out the bobbin and bobbin case and the raceway if you have the type with a drop down gate and clear it.
Posted on Jun 19, 2010
Kenmore sewing machine, Model no. 13550
It needs cleaning and oiling! Do NOT run the motor until you get it taken care of or it can damage the motor.
Wheel on right side that controls the needle up and down is very tight...
Nov 22, 2017 | Kenmore Sewing Machines
Kenmore 19233 sewing machine. Then handwheel is broken, spins freely. Machine works perfectly otherwise. How do I remove the handwheel and replace it.
If the drive belt is not off or broken, then check hand-wheel setting. On some models the hand wheel can be pushed in (to engage) and pulled out (to disengage) for using bobbin winder. If it is disengaged the hand-wheel will spin freely. On older models there is a smaller wheel that has to be hand tightened in order to engage rest of machine. Hope this helps.
Nov 20, 2016 | Kenmore Sewing Machines
Kenmore sewing machine model 158-17031- motor runs well but think the clutch or something is stuck
Has it been oiled lately? If not, it could be seized. Old oil turns to glue and then varnish unless it is regularly maintained. Make sure to use only fresh, good quality sewing machine oil or liquid Tri Flow Synthetic Lube. Slowly rock the hand wheel and apply a couple drops every place where metal rubs against metal--no oil on belts, rubber, synthetic parts! If it is still resistant, direct hot air from a handheld hairdryer into the internal mechanism and repeat the process until things are loosened and moving smoothly again.
A sewing machine should be cleaned and lubed every 40 hrs of working time or every 6 months if not in use.
Oct 03, 2016 | Kenmore Sewing Machines
How do i fix my machin, the engine sounds like it's working, but the needle doent go up or down. The machine number is pfaff creative 1475cd (it's kind of old.)
Does the needle move when you turn the hand wheel manually? If so then you may need a motor belt. If not, check to see if the clutch is engaged (the small wheel in the center of the hand wheel).
Oct 17, 2014 | Sewing Machines
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Feb 09, 2011 | Kenmore 15516 Mechanical Sewing Machine
Model 1802. The hand wheel will turn only with hand force.
This might sound too simple but it might need to be thoroughly oiled. I just got one of these machines from a friend -- it had the identical problem: I couldn't turn the handwheel. The motor was working but the machine would not function. I blasted it with WD40 and then thoroughly oiled it with sewing machine oil. Within a half hour it was stitching just fine. If you use WD40 to free it up, be sure to thoroughly oil it with sewing machine oil immediately after because otherwise the lacquer in the WD40 will eventually gum it up again. Hope this helps.
Jul 31, 2010 | Kenmore Sewing Machines
Hand wheel is stuck
hi there,
well,stuck up hand wheel, is due to mechanical obstruction inside machine,bushing on shafting need to oil,and on handwheel bushing near clutch there is oil port there. since hand wheel are connected to cam shaft with set of gears and pulley is coupled to motor pulley,and other linkage under bobbins,shuttle race etc,broken gears are most common causes of stuck up handwheel,we can consider also the brush carbon,when worn out and damage the rotor commutator brush.if you can open the cover of motor below side of handwheel,you can see the pulley and motor assembly.also on top of machine there an opening to see the top gear assembly,this should be done by service technician.try to bring to nearest service center if still under warranty claim this for lesser maintenance cost.have a nice day,don't forget to rate me.thank's.
Apr 20, 2009 | Sewing Machines
Kenmore 10 stitch needle won't move
hi there,
push or pull hand wheel clutch to engage
motion of needle and shutter.
if not check belt on downside of hand
wheel open cover motor,loosen bolt cover
see belt check if engage on pulley by
holding hand wheel move belt if
hand wheel move,if not tighten screw on
pulley from hand wheel and moter.
have a nice day and thanks
Apr 03, 2009 | Sewing Machines
Bobbin winder does not work on Model 17651
Make sure that the hand wheel is engaged by pushing it in. To disengage, pull it out.
Feb 03, 2009 | Kenmore 15516 Mechanical Sewing Machine
Jan 17, 2009 | White Sewing 1766 Mechanical Sewing...
Sewing Machines Logo
26 people viewed this question
Top Kenmore Sewing Machines Experts
Kelley Buchanan
Kelley Buchanan
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
