Question about Exercise & Fitness
Speed button not working - Exercise & Fitness
    Habit-Forming:
    Scholar:
  • 56 Answers
The make/model would be beneficial in your search for help. Along with a little detail on the past history of the machine and how the issue came to be.
Assuming it is a treadmill. The overlay on the console could be faulty, upper control board, main wire harness, or lower control board.
Posted on Jan 14, 2020
Anonymous
SOURCE:
Why won't one of the spa motors start at low speed?
bad two speed relay on that motor
Oct 10, 2015 | Pool & Spa
VCR just running at high speed..no video nd audio comes out...buttons also doesn't work
Hi, some of the components is worn out because of age or the electronic eye needs attention....
Jun 21, 2014 | Panasonic Televison & Video
Casablanca fan intelli touch
there is a starter solenoid inside it works the speed setting. controls speed 1-2-3. 4 it bypasses it. in side the fan you will see a black box with c66 somthing that will need to be changed as that is the part that controls the speed.
Oct 17, 2013 | Dryers
The speed will not decrease once the treadmill is started. The speed will increase when the button is selected but will not decrease when selected. Everything else still works except the (speed down)...
Most likely the directional PCA has popped out of its housing. There is a small circuit board underneath the quick start button that works the controls. They are notorious for coming loose. If board is still in the housing then then speed down sector of the board may be bad and it will need to be replaced
Aug 13, 2013 | Precor C954i Commercial Treadmill
HUNTER FAN PART # 85095-1
Either need new transmitter or receiver or both. Call 1-888-830-1326 to order parts.
Jan 07, 2013 | Hunter (25417) Ceiling Fan
I used my treadmill occasionally, last time that i used it, the only problem was that the speedmeter was not working properly (I push the speed button, a few seconds later it reset to 0, but was working...
Dear Sir:
Please use the calibration software for easy diagnostic and fit it.
go with your ower manual or go under the Hood for see the instruction steps, and go you will fix it easy and diagnostic , that was the purpose for this software.
Of course i recommen that adjust : 1) Reed sense switch. 2) Sensor speed. and do the calibritation software.
SEE MY BLOCK DIAGRAM THAT I designed to people like you,
for esay diagnostic and troubleshooting too. Sincerely. Merry Christmas.
erensto cuadra
managua, nicaragua.
Dec 23, 2011 | Exercise & Fitness
I have a Kitchen Aid 5 speed blender. After turning it on, the red light blinks, then after choosing a speed it works, but when I hit the OFF button nothing happens. I hit the PULSE button once to stop it...
Hiya,
Sorry to hear you are experiencing an issue with your blender. We believe that the described issue indicates control board fault.
If you have KSB555, please follow the link below to show you how to replace this part on your appliance.
https://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidBlenderHelp/HowtochangetheControlBoardonaKSB555/tabid/650/Default.aspx
https://www.youtube.com/watch?v=Lafh8UGn4No
Hope you found this useful :-)
Aug 22, 2017 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
What controls the speed of a range hood fan? , only when i push the hi button or the low speed button, the hi speed button only works. its a old model built in 1960 , can't find the model number ...
You will need to check inside the button contacts to identify if the control of current is by a series resistor or by the coil winding.
Since the high speed is working it is possible that the series resistor coil is open.So check for loss of contact continuity in the switch, if not you can use the present model of electronic fan controllers to give you a variable fan control. This can be connected to the main hi speed connection.
Tip: Identify the wattage and buy the regulator according to the specs.(42 inch type)
Dec 18, 2010 | Kitchen Ranges
Psp will not load
start PSP while holding down the right button,
this will access bios,
use the 4 way button and the x button to scroll down to cpu speed,
select a higher cpu speed.
you may have to do this several times to get the cpu to the correct speed it was at beforeit stopped working,
i cant recal the correct cpu speed
Sep 19, 2008 | Computers & Internet
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
