One thing which happened to me lately the Ice maker at my job was clicking. I looked up in it if had frozen up I had to defrost it, the clicking went away. Well that may not be help on your freezer but might be the ice maker in it. Just a thought.
Link below talk about the relay and other issues which can cause clicking noise
link below may help
https://www.youtube.com/watch?v=MUWe0gIqH48
https://www.hunker.com/12605063/my-fridge-is-clicking-and-not-cooling
https://www.youtube.com/watch?v=WGGB5IZKk0E
https://www.ifixit.com/Answers/View/156981/What+causes+clicking+noise
SOURCE: Clicking Fridge
I used to have a whirlpool fridge, they are the ones who make kenmore too. It used to make a loud thud noise. It was the compressor turning off. sometimes it was loud enough to wake me up at night. It did this for years and I never had any problems with it. when I purchased a larger fridge I sold it to a friend and its still working today. If you can tolerate the noise I wouldn't worry about it unless it starts giving you trouble.
SOURCE: Have a whirlpool side by side american fridge freezer,,
If the fan in the freezer is working.
You can hear this fan running when you open the freezer. Then I think the noise you hear is the fan hitting an ice build up.
This is a failure of the defrost system.
SOURCE: GE bottom freezer began making a clicking noise, will not run
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it’s bad is to shake it. If it rattles, it’s bad and needs to be replaced. If not, most of the time it’s ok. But rather than saying the compressors bad, you might want to replace it anyways because it don’t cost much in most cases (less than $25). If you replace it and it doesn’t work then the compressor is bad and you’ll need you call a repairman. (Note that compressors are very costly and are normally not worth fixing). You can also enter your model # at www.appliancehelponline.com for diagrams and illustrations.
SOURCE: Whirlpool American Fridge Freezer Clicking noise
my whirlpool amerian side by side it has got warning sign on with a ! at it has stop frezzing
Testimonial: "Thanks very much for your help, really appreciate it "
Thanks everyone just letting you know the fan works the compressor works the condenser works they all run fine. The water and ice maker were disconnected about 3 yrs ago but the clicking only started when our power was turned off because of road works in the street. It hasnt stoped clicking since then
