SOURCE: Replacing the interior lamp inside the microwave on the top.
Yes, Bobby, it can be done. Before you begin, though, go to Home Depot and look in the tool department. There, ask for a "Husky Pro #66604". It's a 1/4" and 5/16" drive 90 degree ratchet that's about 4 inches long. While you're there, pick up a #2 1/4" drive phillips screwdriver bit. You'll use both of these to do the light. Both for about $12. UNPLUG YOUR MICROWAVE! Stand on a small ladder in front of the Microwave (MW), remove the 2 screws that hold the vent louver in place and remove the louver. You'll now see a black plastic grill (just above the door handle)remove the 2 screws with your new tools and remove the grill and the metal box that covers the relay. Now remove the 2 screws holding the horizontal metal panel that the box was sitting on. Now gently lift that panel up, (don't try to remove it) and you'll see the lamp. It's the one with 2 white wires going to it and a shiny metal cover over it. Place your index finger on the back of the cover of the lamp and gently pull toward you and lift at the same time. This will release the catch and allow you to pull it all the way out to get to the lamp. There ya go! Simple!
SOURCE: bottom of GE interior door microwave is burnt/rusted
just use sand paper to clean the rust then use some high temperature paint (sold in tins) eg spray paint but it must be labeled high temperature and spray 2 to 3 coats . your microwave should be safe again
SOURCE: I need to buy a new MBBS Thermador Microwave
I spent the better part of three days trying to find a microwave that will fit and it's hard because so many are on line only. Last night I successfully installed the 2.2 cu. ft. GE profile counter top unit with inverter technology. The unit is an exact match, the Thermador even fits in the GE box with the styrofoam! I installed the venting materials for the side and rear vents and the platform at the bottom. I put the clips and decorative molding on and it's perfect! I found it in stock at Lowe's for $198. I took me about 45 minutes total to install. If I can do it, anyone can - 48 year old mom with 5 kids!
SOURCE: Microwave interior light
Very easy to replace...at least on my JVM1790. Remove the top vent....the long plastic thing that runs along the top of the MW. Two screws on top of the micro. Behind the charcola filter (if you installed one) is an access area to the bulb. remove one screw and the entire assy comes out. Simply R & R the bulb.
SOURCE: is there a replacement microwave for thermador
Thermador doesn't make one, but we found the GE JEB1860SM1SS from Home Depot fit perfectly. For only $259. The repair to fix our Thermador was $618. It was only 5 years old. I couldn't believe it already went out. I won't be buying anymore Thermador appliances.
The manual for the MBES may be close enough:
http://www.thermador.com/site_tools/documents_3.aspx?product_id=68
Otherwise, you can contact Thermador:
