SOURCE: 98 tahoe wont hold charge
Sounds like you have a bare wire somewhere that is touching metal and grounding out. Probably a starter cable. Try unhooking the battery, check the voltage of the battery, then hook the cable back up, watching for sparks from the cable. After you get it hooked back up, check the voltage again. If you see a small spark, it is normal. If you see a big spark, you have a wire that is touching something it is not supposed to.
SOURCE: I recently returned my TTGo720 as the battery
GO720 IM TRYING TO CONNECT TO COMPUTER BUT COM SAY DEVICE NOT CONNECTED BUT CHARGE LIGHT ON GPS IS ON ANY SUGGESTIONS
SOURCE: acer batbl50L4 not holding charge-quick
Its probably quite old, its life is over.
Now you need to buy a new one.
SOURCE: Hi I have a Flip
1) Put your Flip Ultra back into the pakaging box
2) Keep it safely inside your fridge (make sure the fridge isnt on or the best is an old fridge model)
3) Scratch your head and scratch your nuts in the same time for thirty second
4) Turn on your Flip camera, press the red button for setting, and change it to indonesian language. If no indonesian language in the setting, shake it 3 times. It surely has.
5) Jumping around on your parent bed.
6) Sing Britney Spears song and film it yourself.
7) Press stop button
8) Post it on youtube.
I hope this will fix ya problem. Have a nice day :)
