SOURCE: Sharp Microwave Model#R1506 Ser#123663 Mfg
CPWBFB075MRU0.
But we repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: run but does not heats
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food. The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however. Benjamin
SOURCE: I have Zeiss Jena Dekaris 10x50 ser 1740081 what
The manufacturer was Carl Zeiss AG in Jena, Germany. The serial number indicates a manufacturing date of between 1936 and 1940 (1,700,000 starts in 1936 and 1940 starts with 1,980,000) so your's is likely to be around 1936/1937. Some basic specs can be found here
If you're interested in the company history, have a look on wikipedia or check out the website of the Zeiss Historica Society
Hope that helps
SOURCE: Manual for 900W; Ser#5x7x026575;
Hi mary28ok,
There's no available PDF download online for the user's manual. However, you can still get the manual by calling Kenmore's customer support directly. They can send through email the specific user manual you need. Just provide them the model number 565.8948090. You may call them at 1-888-KENMORE
(1-888-536-6673).
Hope this helps.
Thank you for using FixYa.
SOURCE: Where is the main smd fuse located for a dell laptop EASYNOTE Model Hera G mfg date 2009/03/19
I've never seen a laptop with a fuse!!!
