SOURCE: GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
SOURCE: Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
SOURCE: My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
SOURCE: burner heating element stays on high-cannot
there is a thermostat element beside every burner
i think it need to be changed.
thank you
SOURCE: Hotpoint Glasstop Stove - Burner turns on by itself
I have a GE stove which I purchased in 2004, and it is doing the same. I heard beeping coming from the kitchen in the middle of the night . I went to the kitchen and the oven was on by itself. I have been unplugging it when not using it. Maybe this could be a recall.
