To cook with microwave only, press "Microwave/Grill/Combi", once, the screen will display "P100". Press "Microwave/Grill/Combi" to select the power level. Then press "Start/+30Sec./Confirm" to confirm and turn the dial to set cooking time. Then press "Start/+30Sec./Confirm" to start cooking on microwave only.
To switch to microwave/ grill combination cooking, choose C1 or C2 when selecting the power level.
See page 14 and 15 in the user manual.
SOURCE: Kenwood microwave (KEN GJ/SS25) heating doesn't work but grill works
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
SOURCE: Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: I have a panasonic NNA883w
If
the digital programmer circuit / controller does not get a feedback
signal from the inverter for a period of 3 seconds, the controller will
stop the cook cycle.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these inverter-based models.
You can find an authorized Panasonic servicer here.
SOURCE: Tesco Combi Microwave-doesn't cook but grills ok
Hi! the problem you have mentioned indicates that your microwave magnetron is not working. check for busted fuses.
SOURCE: hi i have a bosch combi microwave/grill/oven and
dont need new door glass is replaceable very cheap but tricky to replace
