Question about Xerox Office Equipment & Supplies
Xerox 700i , Please Any one know how I can get the latest software for the xerox 700 IOT unit ?
5 Suggested Answers
Anonymous
SOURCE: Xerox One Touch Scanner 4800
please, send me the driver for
Posted on Oct 13, 2008
SOURCE: i have a xerox 7750, error code 9-913
This problem occurs when you buy the wrong image unit.
The contact chip that is located at the bottom of the orange plastic is not for the machine. Replace it with 7750 image unit and that should fix your problem. Black is fault 9-910 cyan fault : 9-911 magenta fault: 9-912 yellor 9-913.
Posted on Oct 22, 2009
Anonymous
SOURCE: Xerox Phaser 6250 won't print colour in Windows 7
Hello!
I had same problem and it was driving me crazy. Try this one:
Control panel -> Devices and printers -> xerox printer with mouse right click
Printer properties -> Options
From list you'll select configuration and it gives you drop down menu and from menu you need to select your printer.
I didn't try this one yet because more solid ink is still on the way but this gave me all printing options back. Before basic printing mode was selected.
Funny stuff, uh?
Posted on Mar 18, 2010
Testimonial: "see my added comments - thanks again"
Anonymous
SOURCE: Printer Error Fuser Temp. in xerox 3100mfp
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
Posted on Jul 04, 2010
ca555
  • 57 Answers
SOURCE: Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Posted on Jan 22, 2011
Error code 004-350. What is it?
That error is an IOT video failure. It tries to reset itself, but if it doesn't you'll need to reload the software on the printer which requires the Xerox PWS Laptop.
Jul 21, 2015 | Xerox Workcentre 7345 Printer, Copier,...
XEROX, DC-12... How do I fix eror 10-398 Please help me...thanks
10-398 Fuser Fan Failure RAP
See Service Manual pages 2-175 (10-398 Fuser Fan Failure RAP) and 6-131 (How to Enter/Exit the UI (IOT) Diagnostics Mode):
XEROX DocuColor12 DC12 Service Manual free download schematics datasheets...
(download parts 01.rar to 09.rar and unpack)
Jun 01, 2015 | Xerox DocuColor 12 Printer
Anybody know technicians in NJ area for Xerox 700, please
Hi Oscar,
I see you bought a used 700i. I assume you didn't receive a maintenance agreement with the product.
I have some advice for you:
You can purchase a maintenance agreement on Xerox equipment new or used.
First contact:
Xerox Corp
101 Woodcrest Rd, Cherry Hill, NJ 08003
(856) 651-2000
Explain that you have a Xerox 700i without a maintenance agreement
and you would like a certified Xerox Technician to come onsite and
inspect your device to see if it qualifies for a maintenance agreement.
If your device can qualify it is more economically friendly to purchase
an agreement than it would be to have a tech go there and repair it once
Simply put, the one service call could be more expensive than a 1 year
I hope this helps and if you need more info get back to me...
Mar 06, 2015 | Xerox Office Equipment & Supplies
Error code 9-342 at start up of Dc 12 xerox printer/copier
change the IOT back side clutch that appear behind the back side of machine which rotates the ITO (black roller in main path of paper) just try with cleaing clutch other wise change it
and remove that IOT back side gear which rotate IOT black roller without that gear u can print
i solve my problem with this methods
Mar 28, 2010 | Xerox DocuColor 12 Printer
A code 041-345 has appeared on the dc 700 and the code is not in the xerox manual. What does the code mean?
we had the same problem. fuse f2 on iot board was blown. fixed it buy soldering a new fuse
vikas
agra
india
Nov 05, 2009 | Xerox DocuColor 12 Color Copier
Xerox DC12 gives error 14-372 please HELP!!
ERROR 14-372 ROS MOTOR FAIL , ITS THE MOTOR THAT ROTATES THE POLYGON OF THE LASER BEAM , ITS LOCATED , BELOW THE SCANNER UNIT AND OVER THE COPY/PRINT CTG. 13R557/13R558 . IT CAN BE ONE OF 3 THINGS THE ROS ASSY. (LASER SCANNER UNIT OR ROS) , IOT DRIVE PWB(THE PC BOARD BELOW THE NVM AND IOT-SYS) OR A PROBLEM ON THE WIRING HARNESS / POWER SUPPLY. WE CAN REPAIR THOSE UNITS OR I CAN PROVIDE YOU THE PART NUMBERS IF YOU WANT TO ORDER THEM NEW FROM XEROX . diesco_cxl@hotmail.com
Mar 23, 2009 | Xerox DocuColor 12 Printer
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
