Question about Tablets & eReaders
How do I put my apps on external storage instead of internal, on my dragontouch K10
    Top Expert:
  • Tablets & eR... Master
  • 30,886 Answers
sirfandrews
  • 11 Answers
SOURCE: How to move app internal storage to phone storage?
Root your device. Then use System app remover. Transfer everything to SD card.
Posted on Jan 08, 2017
We have a lenovo tab2 A8, with a 64 GB microSD card installed. With both netflix & amazon prime video, in options, there is no selection to download to the SD card instead of the internal storage.
First, go to Settings > Storage and check if the "Default write disk" is set to "SD card". Then go to Settings > Apps and swipe to the left until you get to "SD card". Below will be all the Apps that can be be moved to the external SD card. Click in the box on the right and another page will come up. About in the middle of the page will be "MOVE TO SD CARD" tab. Tap on it and wait until it finishes. Then go back and pick another App to move. You should be able to download apps directly to the external SD card. I haven't done that on this device and not all apps will download to the external SD card (the app maker can restrict downloads to only the internal memory. This tablet is one of the rare few Android devices that allow moving Apps to external memory.
May 25, 2017 | Amazon Tablets & eReaders
I have put 32 gb sd card into excelvan tablet for external storage and its not saving?
Unfortunately, most apps will not load onto an SD card. You'll find that some apps will, if a card is installed, place data there. Mostly the SD Cards are installed for use in storing photos and videos taken by the user with the tablet camera. Newer tablets and smartphones are coming with more and more internal RAM to alleviate the "full" issue, but in most cases, you wither have to give up the new app, or remove one to get another.
Aug 31, 2016 | Tablets & eReaders
How do I download apps onto this device?
The default on most tablets is to install apps to internal storage so the SD card does no good by itself. You can go into Settings>Applications and change the location for each app to the SD card. Likewise anything else you put on a tablet, particularly photos and videos get stored in internal storage. If you have taken a lot of photos and videos they can fill up your storage quickly. You can change this in the Camera app by tapping the settings icon and changing the storage option to SD card. You will still need to actually move existing photos and videos to the SD card manually or copy them to external storage and delete them. I would also change the image and video resolution in Camera settings to 640x480. This is plenty good enough for pictures you just want to look at on the device or share online.
Jan 04, 2016 | Trio Stealth G2 7 inch Tablet with 8GB...
I placed a 32gb TF card in my tablet, went to download a app and msg says not enough space. What am I doing wrong?
Maybe nothing at all. Apps, depending on how they are written, may use only internal storage, SD (TF) storage, or a combination of both. If you are getting a "not enough space" message, chances are the app is not TF friendly. Cell phone users have the same issue with apps not wanting to use the internal card storage. Until tablet/phone makers put more internal memory in their devices, or until app writer make their apps available to the extended storage, this problem will continue.
Oct 27, 2015 | Tablets & eReaders
How do you movemove an app to the sd card from the internal storage?
Usually, if you go into settings, it should be under Storage. If it can be done, the app will come up with an option to 'Move to External storage'.
Mar 05, 2015 | Tablets & eReaders
How does ram vs internal storage work on tablet?
There are 2 storage in just about every smartphone or tablet. There is an internal storage, usually about 1gb. or 2gb. And there an internal SD storage, which is not same as the external micro sd card. RAM stands for Read Access Memory, it will not work as storage. Now, when you download an app it is usually save in the internal storage. If you move an app without an external micro sd card inserted, you are moving them to the internal SD storage. If possible got to setting>storage and check how is the storage divided, if you insert the external micro sd card it should display 3 separate bars. Also, another way to move apps and other things around is by using ES File Explorer. Check that out first and I hope you do resolve the problem, best of luck.
Jan 22, 2015 | Tablets & eReaders
I have an irulu tablet. I inserted a 32gb sd card. It says it is mounted and when i try to install an app from the google play store i get the message there is insuficient space available. how do i get it...
Most apps do not natively install to an SD card when downloaded from the play store. You have to have an app like AppManager, that has a function to 'move' apps from internal storage to an SD card, or use a manual option in the Android Settings section to move each app individually.. If you are that tight on space that you cannot load any new app, you may have to delete or move something from your internal storage so you can download AppManager or some similar app, and then move as many apps as you can to your SD card. If you have a lot of photos and music you can try moving that to the SD card if your player/viewer software will allow you to find it there. Best way to move bulk items (music/photos, not apps) is to connect to a PC through USB, which brings up your internal storage and the SD card as external USB storage items. Then copy from internal storage to SD card through your PC. Best to establish folders on the SD card to hold these items and then tell your app where they are.
Dec 03, 2014 | Tablets & eReaders
Why can't I install app. after they are downloaded
What messages are you getting when trying to install? The app is not necessarily installed to the memory card automatically. Check your settings. How much internal storage space does it show? The app might be too big for the space you have left. You could try to free up some space by moving some installed apps to the SD card.
Internal storage and external storage on your sd card are two different things.
May 07, 2014 | Proscan 7-Inch Android Internet Tablet,...
I have a pandigital black novel tablet And I And unable to download any apps and all my apps have been erased. And my sd card is not working b c when I try to download a app It tells me that I dont have...
Tablets have internal storage and external SD cards (optional) storage. Apps will download to the internal storage. So under Settings > Storage make sure you have space on your internal storage.
Dec 30, 2012 | Tablets & eReaders
Tablets & eReaders Logo
76 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
