Toothpick and paperclip mentioned, but disassembly instructions are given.
https://blog.jonschneider.com/2009/02/wii-overheating-and-powering-off-due-to.html
SOURCE: can't read any of my disk.
Basic but !
Are you inserting the disc righy way round?
Try putting in in opposite way and see if that works.
SOURCE: unable to read disk
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
139
SOURCE: wii will no longer read wii disk and tried different wii disk.
try unplugging it for at least 5 minutes and then plug back in and retry.
SOURCE: installed a new laser for the nintendo wii and
Hi
there From
what you have said it sounds like you have the DISK DRIVE READ ERROR The
main cause is Hardware failure due to overheating or just simple wear
& tear.
You
will need to perform simple maintenance to your console You
can send your Wii to Nintendo to fix this. If your in warranty its
free. If not the repair cost would be $150 and a wait time of 4-6
weeks The
other solution is what I did and the way more and more gamers are
turning nowadays is a Good
Wii Repair Guide that shows you how to fix the problem yourself.
I have never had a problem with this one so far for over a year, well
worth it. Its my most recommended guide online. Well
this is all the help and advice I have on this so good luck. You
can get back to gaming Please
come back and rate my post if you find it useful Many
thanks Chris
Foley
