Question about Cameras
I have a Cremona Trail Camera which has stopped working. Batteries are fully charged and SIM card is empty. It’s showing a symbol on the top left corner, in red, which looks like a SIM card.
    Sergeant:
  • 181 Answers
I think the SIM card is bad - try another one.
Posted on Feb 06, 2020
Anonymous
SOURCE:
Anonymous
SOURCE: Need to unlock Centrex TV model CTT6809SF
Hold down the plus key (bottom right) for 4 seconds
Posted on Feb 09, 2008
Anonymous
SOURCE: game down loads and symbols
log on to the fixyaweb site and toards ur right hand u can find the ringtones option in blue colour and under it the games option is available follow the instructions and download the required game
kimmyj511
SOURCE: Deleting missed call symbol
Hi you go to your answer button with is the green phone thingy. you press it ,as it opens it will show you the missed calls ,press on the missed call you received then you'll have the open button option. Just open it and the missed call red arrow ,should dissapear.
Posted on Dec 02, 2008
Anonymous
  • 76 Answers
SOURCE: Blackberry says to insert sim card and has a red sos symbol
Replace the SIM Card with your service provider
Posted on Jun 06, 2010
supernova278
Udhaya Rajan
  • 1932 Answers
SOURCE: flashing message symbol at top of screen says SIM
To get rid of this flashing message symbol please delete the sim messgaes.
To delete the sim messgaes follow the steps,
Menu--->Messages--->Options---->Sim messgaes
open it and you can delete the sim messages.
You wont get the flashing message symbol
Thanx
Posted on Jul 23, 2010
Can't get bushnell trail camera 8mp to come on
Use lithium (non-rechargeable) high energy batteries for best results. This is clearly a power supply problem. If it doesn't work, send it back for replacement. If the batteries are self-contained, ensure they are fully charged using the charger supplied with the camera. Remember, rechargeable batteries are only good for a maximum of two years. Cameras, in general, do not work well with rechargeable batteries as the voltage is less, i.e.; 1.25 volts vs. 1.5 volts per AAA/AA/C or D size battery.
Aug 27, 2012 | Acer Cameras
I just bought a tasco trail camera. I set it up by the manual that came with it. It will take a couple of pictures and then it seems to shut off. If I take the batterys out and reinstall them it will work...
Hi.
Are the batteries fully charged? It is recommended that you fully charge the batteries first before you use the camera as the camera can literally eat batteries.
If you have fully charged the batteries and the camera still only allows you to take a few shots then I suggest that you take/send the camera back and have it replaced.
Regards.
Apr 28, 2011 | Cameras
Can't charge battery. The battery symbol is red. What do I do?
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Dec 31, 2009 | Kodak EASYSHARE M340 Digital Camera
Charged Battery, Half Symbol!
maybe the batteries are old? i had this problem once. i just bought new ones.
Dec 09, 2009 | Nikon COOLPIX L100 Digital Camera
Camera suddenly stopped working--an error message flashed, then camera shut off-put new battery in--nothing happens. (kodak c360)
Usually when the camera shows an error mgs. it needs a repair
However Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 23, 2009 | Kodak EasyShare C360 Digital Camera
Camera shows battery exhausted with new batteries.
You should be using Nickel metal Hydride batteries (NiMH). Do not use Nickel Cadmuim(NiCd), Zinc carbon or alkaline.
Mar 12, 2009 | Nikon Coolpix L1 Digital Camera
Battery empty message
Put brand new batteries in. The battery empty message means there is no "juice" or power left in the batteries. If they are recharagable batteries, "re-juice" them (charge them).
Nov 24, 2008 | Olympus FE-230 Digital Camera
Camera still won't start...
hello, Dont worry lady, i think your problem is related to memory card. i suppose that you did not format memory card regularly, so format your memory card specific in your camera. and then try. i hope you deffinnately succeed. good luck...
Jul 30, 2006 | Olympus Camedia C-350 Digital Camera
Cameras Logo
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
