Televison & Video Logo
S
Suzanne Posted on Jan 18, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Running man symbol turned from green to red on Apple Watch series 5
Terry
Level 3:
  • Apple Master 11,377 Answers
  • Posted on Jan 18, 2020
Terry
Apple Master
Level 3:
Answers
11377
Questions
Helped
4626538
Points
152765
Apple store in shopping mall can give assistance.
Possible charging indicator:
https://support.apple.com/guide/watch/charge-apple-watch-apd2b717523a/watchos
M Apple Watch has a black face with a red lightning icon on top left and green numbers on top left. Cannot change face. It was charged over night
When the Apple Watch displays a red lightning bolt, battery life is critically low. The watch has automatically entered Power Reserve mode, and the device can only show the time.
The only way to remove the red lightning bolt and leave Power Reserve mode is to charge the Apple Watch.
To exit Power Reserve mode with a charged battery reboot the Apple Watch.
Will bands for my current Apple Watch fit the new Series 2 model?
yes it will as long as its the same size watch face
How do I add people to my contacts?
If you click on the green phone button then go down to the contacts button on the bottom of the screen then look at the top right corner of the screen there will be a + symbol click on that symbol and follow the prompts for name phone number Ect....
If you need further help, reach me via phone at https://www.6ya.com/expert/jeremy_075aa344198c3329
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
80gig ipod, dropped it, turn on when plugged up, either a red circle with a red x on it or the apple symbol appears
http://support.apple.com/kb/TS1463
http://support.apple.com/kb/HT1363?viewlocale=en_US
These two websites will walk you through the fixing process_ good luck
My ipod plays video for a while then it suddenly stops and goes to the menu home page
your iPod touch might just be running low on memory. to fix that, all you need to do is reboot your device.
now, to reboot your device, simply turn it OFF by holding the power button for around 3 to 5 sec until you see this screen:
.. then continue by sliding the red bar on the top.
After your device is completely turned OFF, turn it back ON by holding the power button for (again) around 3 to 5 sec. Wait for it to load completely and then after, you can watch the video you've been dying to watch without any interruption, except for the weak WiFi signal.
For more iPod touch / iPhone tips, click here.
System fan does not come on.
if the out door unit has been working carefully jump red to green the fan should come on if not problem is bad fan motor or capicitor or fan relay hope this helps
What does the little electrical bolt symbol mean?
this is obviously a power or connectivity issue, check that the device ( your ipod ) is correctly seated into the logitech speaker system, and check the power cables are connected according to the manual which came with the logitech speaker system.
question u may ask yourself? - does the ipod work as it should on its own? (without non-apple devices/components attached to it) - if it doesnt - take to an apple store or call or seek apple support.
it sounds like your ipod is low on power from source.
i hope this directs you in the right direction, party on!
Top Apple Televison & Video Experts
john h
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you an Apple Televison and Video Expert? Answer questions, earn points and help others
