Dennis Emrick Posted on Jan 18, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The toner light on my hp1606dn won't go off and the printer will not print. Can I fix this. The cartridge is a HP cartiridge
Leroy Elliott
Level 3:
Fixya-Fanatic:
Visited the website for 90 consecutive days.
  • HP Master 425 Answers
  • Posted on Jan 24, 2020
Leroy Elliott
HP Master
Level 3:
Fixya-Fanatic:
Answers
425
Questions
0
Helped
137084
Points
1154
Did you pull the tape?
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Mar 21, 2008
SOURCE: Toner light
The HL-2070N gets jammed in a toner end-of-life error condition. Perform the following to clear (I have 120 in the field so I know it works!):
With paper loaded, new toner in,
  1. Open front door
  2. Turn off printer
  3. While holding down the GO button, turn printer back on
  4. When all four LEDs light up release GO button. All LEDs will turn off
  5. Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
  6. Press the GO button 5 times
  7. Paper light will be blinking
  8. At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Anonymous
  • 52 Answers
  • Posted on Mar 06, 2009
SOURCE: HP DeskJet 930c is leaking black ink
The printer primes and cleans the cartridges when the cartridges go to the right side of carriage. Sounds like a cartridge has either leaked or you have used it enough the the ink pool is full, or you have layed the printer on its side or back. From experence, if ink is leaking out of the printer, your probley better off getting anithe printer. I have tried to take the covers off and clean inside print, and it is a messy job.
Anonymous
  • 113 Answers
  • Posted on Apr 24, 2009
SOURCE: Received "Low Toner" message. Replaced toner with new Brother cartridge still have "low Toner" meaasge and [printer will not print.
Please check if you removed the Plastic Tapes which is placed in the side lock of the new Toner Cartridge.
Anonymous
  • Posted on Aug 26, 2009
SOURCE: replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Anonymous
  • 360 Answers
  • Posted on Aug 31, 2010
SOURCE: I have an samsung printer
hello ,
replace new toner chip
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
1helpful
HP Color Laserjet Cp2025n Printer - driver says it's out of toner and won't print. No true. I put in new toner cartridge last week. How do I get it toreceognize the new toner?
Did you purchase a new OEM HP toner or a refilled or remanufactured toner. It is possible that the chip is bad on the cartridge in which case if it is a true HP cartridge have them replace it. If you purchased 3rd party go after the vendor to replace it.
2answers
My hp laserjet printer 3055 printing out put is blank sheet is coming
This can be caused by a number of reasons however it is mostly caused by the toner cartridge missing a small spring on one end. Try replacing toner cartridge first.
1helpful
2answers
I have a one inch streak down the middle of my printed page on my HP laserjet 1600 printer
Streaks (thicker lines) indicate faulty PCR Roller which is located behind the green drum inside the cartridge. As the printer has 4 cartiridges, you have to identify the faulty one. You may replace the cartridge or get the PCR Roller changed by a professional.
Let me know if any further clarification is required. Hope this helps!
CreatuiveTECH
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270) . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345) . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com. 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
2helpful
2answers
HP Q2612A Cartiridge refilling
YouTube - Toner Refill for HP Cartridges 2600, 3600, 3800 etc
3helpful
3answers
HP Laserjet 2015 dn
It means that the printer is in READY State.
Control panel
The printer control panel is comprised of six lights and two buttons. The lights produce patterns that
identify the printer status.
1 Jam light: Indicates that there is a jam in the printer.
2 Toner light: When the print cartridge is low, the Toner light illuminates. When the print cartridge is out of the printer,
the Toner light blinks.
3 Paper out light: Indicates that the printer is out of paper.
4 Attention light: Indicates that the print-cartridge door is open or other errors exist.
5 Ready light: Indicates that the printer is ready to print.
6 Go button and light: Initiates action or indicates status.
7 Cancel button: To cancel the print job that is currently printing, press the Cancel button.
Brother MFC-8500 prints solid gray pages
I have seen the Toner cartridge in these cause this and also thought it was drum but new toner actually fixes it, have you installed new gen toner as well as drum? Make sure you tell machine you have fitted new drum too,
My printer won't print multiple pages
The Toner is running low. What is happening is you are low on toner in the MIDDLE of the Cartiridge. Take the cartridge out and jently shake it left to right (be careful you dont make a mess) this will distribute the toner evenly. time to buy a spare as this wont last much longer.
k24674
Grand Canyon Tech
Grand Canyon Tech
