2 screws on the bottom. then two tabs on back and two on side use flat head to separate cover at tabs
Maybe the info below provides some help.
https://www.youtube.com/watch?v=HSASJaG9Q2E
https://www.youtube.com/watch?v=dcB4UNTbG2M
https://www.youtube.com/watch?v=4-Hyt5_CPi4
https://usermanual.wiki/Kenmore-Elite/11621814410.594123306/view
The manual above has some disassemble instruction
https://www.manualslib.com/manual/1323502/Kenmore-Elite-116-31150.html?page=5#manual
https://www.manualslib.com/manual/563958/Kenmore-214-34000.html?page=11#manual
SOURCE: Kenmore Powermate Canister Vacuum Cleaner
Depending on which model, there is a couple of scres on the bottom, then on each side and back are release catchs that you pry up to release the top, then you can get to the belt. The other model you take off the light cover, it just snaps in place, then you can take out 2 screws from the top, on each side there is a slot, put a screwdriver up into the slot and pry out to release the tabs, then the cover comes off and you can get to the belt.
SOURCE: Need the manual for this vacuum cleaner
Try this link also
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action
SOURCE: Instructions on changing a belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=825812
Generic problem for all Vacuums
Posted by ed_maxwell on Jul 24, 2008
Instructions on changing a belt on an Elite Hoover Vacuum Cleaner Model # v5075-930 Serial # 089500053577
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Knowing the brand name and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: how do I change the belt on my Hoover Elite Dual
The hoover belt number you listed (38528027) has been changed by Hoover to 38528040. Below I have listed a link to the manual that has instructions and a link to the belt you need. Hope this helps!
Hoover Elite Manual
Hoover Elite Replacement Belts
SOURCE: My deluxe elite rewind vacuum spits out dirt
The elite rewind does not have any fancy features. This sound like you have a blockage in the foot or base of the vac. remove the bottom cover to look under. Also check the hose, it can be in there as well.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
