Question about LG Televison & Video
LG 50LN5700 has horizontal bands 2 or three of what looks like high frequency noise that pop on and off the screen at regular intervals.
    Top Expert:
  • LG Master
  • 10,764 Answers
Change power outlet see if goes away and check connections possible feed back from source if all ok possible bad video board
Posted on Jan 24, 2020
Anonymous
SOURCE:
Anonymous
SOURCE: Danby Air Conditioner
I have the same problem with my Danby AC unit...every 5-20 seconds it makes a god awful clicking noise...Make me wanna cry
Posted on Jul 30, 2008
Anonymous
SOURCE: shimmer and bands
i experienced a tainted vertical black lines on the boths sides of my lcd screen. There was no scratch or whatsoever that could be the reason why thsi balck colored vertical lines to spread. Hope you can help me solve this problem. Thank you..
Posted on Oct 28, 2008
taran_2005
taran_2005
  • 10515 Answers
SOURCE: broken horizontal stripes except for 6" band
there are two convergnece boards in this tv. one is called the convergence (DCU) the other is called the convergence amp board. this amp board has the (STK`S) on it and ids your problem. in most cases we repair this board.
good luck :)
let me know if you need more info?
Posted on Jan 11, 2009
Anonymous
  • 1139 Answers
SOURCE: ps 27123 have sound, tuning etc only small horizontal color band
Hello bdedrick708,
If what you are trying to say is that you have a 1/4 inch horizontal line across your screen, this means that something in your vertical deflection circuit has failed. This could be the vertical oscillator, the vertical output processor, the vertical coupling capacitor, or the vertical section of the yoke transformer.
If what you are talking about is a vertical line from top to bottom then you are possibly talking about a failed horizontal section of the yoke transformer.
Why so little about the horizontal section of the yoke? That is because if the horizontal section fails completely then you would lose high voltage and no line would be present because you would not have raster (screen light).
In any even check the yoke transformer first. Then work back from there.
I hope this helps,
Thank you,
Shuttle83
llc
.com/">http://www.electron-age-technologies-llc.com
Posted on Feb 08, 2009
Anonymous
  • 102 Answers
SOURCE: a three loud consecutive popping sounds at various
You probably have a bad compressor. It's internal parts are held up with 4 springs and one of them has probably broken and causes the compressor piston to hit the side of the comp. housing. This will happen when the ref. shuts off. To be sure, if you turn the ref off at the controls then you should hear the noise in the back. If it is less than 5 years old you can get it replaced under warranty. if more than 5 years old it will just be noisy. it will most likely last several more years like it is. Let me know if I'm right.
Posted on Apr 01, 2009
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
How to fix horizontal lines on LG TV
Not sure if this is recent but in settings adjust picture size to fit. Top to bottom side to side.
sounds like you are seeing what are called retrace lines
Sep 30, 2016 | LG 50" 5700 Series LED HDTV - 50LN5700
How do i fix an FM freqency problem?
What is there to fix? You have now access to a larger interval of tunable frequencies. There are two or three selectable FM ranges. In Japan you can tune between 76 MHz and 108 Mhz. In North America the range is between 87 Mhz and 108 Mhz. There is 3rd one called School Band but I do not recall the limiting values.
Jul 09, 2014 | Sangean PRD5 AM/FM/RDS Radio
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
I put a sub in my 2002 Altima but when I turn it up the bass cracks on the door speakers??? What do I do to get all the bass on the sub
Hi Ethan,
What you're looking for is called a "crossover". A crossover is an electronic filter for an audio or speaker circuit. In an audio circuit, a crossover is used to prevent or pass certain frequencies or a range of frequencies from passing through it. Since your sub will reproduce the bass or low frequencies, you don't want other speakers to reproduce them. A band pass filter on your door speakers will do this for you. A band pass filter passes only a range or "band" of frequencies and blocks those that are above and below the range or band of frequencies selected. Installing a band pass filter will prevent the very high & very low frequencies from getting to the door /dash speakers. Likewise, you should consider connecting a low pass filter to your subs, too. The low pass filters work a little differently from of the way band pass filters work - they only allow low frequencies to get to the sub - blocking all the other higher frequencies (your other speakers are better suited to reproduce those). Lastly, you would install a high pass filters on tweeters. Tweeters are designed to reproduce only the high frequencies - sending mid and low frequencies to them is wasting power and can cause damage to them.
You purchase the filters for specific crossover points (the block / unblocked point) as determined by the individual speakers. If a sub has a frequency response of 20Hz - 100Hz, a low pass filter of 100Hz would be ideal. Remaining filters would need to begin at 100Hz - assuming the mid-range speakers have a frequency response beginning at 100Hz. A band pass filter of 100Hz - 3KHz would fit the bill nicely if the mid-range speakers go up to 3Khz Match the high end of the band pass to the high end of the frequency response of the mid-range speakers. Next, a high pass filter at 3KHz would allow only the high frequencies to your tweeters. Basically, you want to have the entire audible range 20Hz - 20KHz covered by the speakers and have the crossover points that match the frequency response ranges of the speakers.
I hope this helps & good luck!
Apr 12, 2012 | Pioneer Car Audio & Video
Horizontal flashing color stripes.1/2 second intervals on pic
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 07, 2017 | LG 42PG20 42 in. Plasma HDTV
Shimmer and bands
Jul 12, 2008 | LG Flatron L1710M 17" LCD Monitor
Rear projection TV (LG 44SZ51): Horizontal dark band on upper screen field
The LG 44SZ21RB Have a problem with their light tunnel collasping due to the heat from the lamp. They are available as a spare part @ LG and would also require some silicon adhesive to bond it into the assembly. Very tedious job for any technican (2-3 hrs). Lg will not release parts to the general public only to an authorised LG agent.
Mar 30, 2008 | LG RU-44SZ51D 44" Rear Projection...
Shows nothing but cross horizontal bands
The monitor may not be able to handle the settings of the video adapter. If you boot into safe mode (tap F8 key as the computer starts), does the display appear correctly? If so, then you just need to turn down the settings (resolution, color quality, frequency) to the lowest possible settings. If the display still appears wrong, then it may be something wrong with the monitor. You can try connecting the monitor to another CPU and see if you can replicate the results.
Sep 14, 2006 | LG Studioworks 45 14" CRT Monitor
Televison & Video Logo
102 people viewed this question
Ekse
RONALD CARTER JR
