Question about The Health & Beauty
I have a Quickie S-11 powerchair, When I charge it and unplug the charger the controller flashes as if it were still charging and I cannot start chair. Can I reset the chair?
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Esophageal cancer is cancer that occurs in the esophagus a long, hollow tube that runs from your throat to your stomach. Your esophagus helps move the food you swallow from the back of your throat to your stomach to be digested. Esophageal cancer usually begins in the cells that line the inside of the esophagus.
Posted on Jan 21, 2020
Anonymous
SOURCE:
Anonymous
SOURCE: lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Posted on Apr 14, 2009
Anonymous
  • 32 Answers
SOURCE: Aspire Quickie Battery Charger
most chargers have an external or internal fuse, try replacing.
Posted on Jul 13, 2009
Anonymous
  • 29 Answers
SOURCE: the orange idicator light is flashing.
Replace the batters and used the correct battery charger, Not a car charger.
Posted on Sep 02, 2009
HoverTech
Donna Angelo
  • 232 Answers
SOURCE: The chair won't power on and the batteries won't
After you changed the batteries, did the power chair sit unused for several weeks? It sounds more like a battery or fuse issue than a charger issue. If there are blinking lights when you try to turn the power chair on (not while attached to the charger), or it comes on then goes back off by itself quickly, there may be something else going on.
1- The green light on the charger is telling you that the batteries are not accepting any more power, either they are fully charged or they have oxidized/gone solid from sitting without being put on the charger for too long.
2-The scrolling lights on the controller when the charger is plugged in just confirms that the chair is connected to the charger, so it sounds like everything is connected properly and working. The horn will work fine when it is attached to the charger as it is getting power from the wall outlet.
3- If it was a fuse issue, the lights would not come on at all when the charger is NOT attached, even after the battery has been fully charged, which is what it sounds like is going on. The fuses can blow if you operate the chair on a slick surface or one of the drive tires spin out. The batteries will be fully charged but because the circuit is not complete, the chair will not power on.
I recommend checking the fuses and changing them if necessary. You are in luck because this is a relatively easy and inexpensive fix as they are standard automotive fuses found at any auto parts store or even Walmart for around $2 each (you need 2). The fuses are located inside the gray battery covers under the seat, attached to the leads connected to the battery cables. The straps holding the covers on the batteries are tight, you may want to use a flat head screwdriver to help release the clips. While you are down there, inspect the tread on the tires, if it is worn or slick it may need to be replaced for safety.
I hope this information is helpful to you- good luck!
Posted on Dec 27, 2010
douglass smith
SOURCE: I have a Jazzy 1113 powerchair and the on board
my chair jazzy 1113 ats won't move.all the lights are flashing and the batteries are fully charged why are they flasng
Posted on Apr 28, 2011
I have a jazzy Select GT power scooter, on the charger I have a red light and green, I put it on charge and have both green lights on now but the controls near the joy stick and on and off light nothi
need more info on equipment to answer ,scooters dont have joystics powerchairs use joysticks if you have a powerchair that has not been charged for over two weeks the batteries have probably died
in this state the charger will not go into charge mode only the power light and poss the fully charge lights will light
as a quick test a 24 volt bulb from a scooter or lorry with 2 wires attached pushed into the two outer holes in the joystick charge socket should light up if it wont batteries are totally dead
Nov 21, 2014 | Health & Beauty
My chair will not move and the charge light flashes continuously, both when the charger is plugged in and when it is detached.
The VSI controller is manufactured by Penny and Giles Drive Technology. A picture of all the flash codes and their meaning can be found at:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
This is a terrific way to diagnose the problem with your chair. A technician will have a hand held programmer to read all the faults stored in the VSI controller log. This will give you an overall picture of the condition of all the electrical components of the chair, past and current faults. Hope this helps.
Jan 19, 2011 | Quickie Wheelchairs Quickie Aspire Power...
Have a Sunrise Aspire chair w/new batterie, charged by the repairman. Want to keep it charged regularly (not let it run down). DO I NEED TO TOTALLY DISCONNECT THE POWER HOOKUPS IN THE BACK when I...
You do not need to unplug the large 9 pin beau plug in the rear or the smaller 3 pin molex plug when you charge the chair. Do not unplug them or you will not charge the chair.
Use your charging cord as you describe "plug it into the front, plug it into the wall and charge, then unplug the charger cord and GO". Hope this helps.
Jan 05, 2011 | Quickie Wheelchairs Quickie Aspire Power...
When i plug in the charger the led light stays on green but on the joystick the lights are moving back and forth as if it is charging but wheelchair does not move
Joy When you plug in the charger the lights on the joystick will scroll because of something called charger inhibit which disables the joystick when charging It is a safety feature. Now when you disconnect the charger turn off the chair and then turn it back on you should then get all the battery lights indicating the charge level If fully charged all the lights will be lit. If after you unplug the charger and you still get the scrolling lights then you have a problem with the charger inhibit function in the joystick and it will have to be replaced. Hope this helps you
Sep 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
The wheelchair will only move when the charger is plugged in. Unplug and all lights are normal but no motor actuation. thank you fo4r your help
berry boy Not alot of information but when you say all lights are normal do you mean the battery level lights are all lit up and there are no flashes. Usually when this happens the battery level is too low to make the chair move. When you have the chair plugged up the charger gives enough power to make it move. If you have a digital voltmeter set it 200 vdc then plug the 2 test leads into the 2 outter charger port holes. You should be able to read the battery level and after a full charge should be reading 25-27 volts. Hope this helps
Sep 19, 2010 | Quickie Wheelchairs Quickie Aspire Power...
My wife has a Quickie V-521 that is full charged however when you disconnect the charger all the lights flash and the reset button is depressed and will notpop back out
Make sure the chair is not in freewheel mode. Also just because the batteries read fully charged does not mean that they are "good" batteries. Have them load tested. As far as the reset button, the normal positon is pushed in.
Oct 10, 2009 | Quickie Wheelchairs Quickie Aspire...
My suns Quickie P320 (dual battery) requires very
Rapid discharge usually is a sign of weak batteries, and they should be replaced if the charge indicates that they are full after charging for several hours, and then dissipate rapidly.
If your not getting a full charge indication after several hours, then you need to check the charger to make sure it is putting out about 28 Volts DC. If it is, then it is for sure the batt's.
The sweeping lights should not occur when the chair is off the charger. They sweep while on charge to tell you that it is charging and you can't move the chair. If they sweep while off the charger, turn off and restart and it should go. If not, call a tech. rep. for Quickie.
Sep 29, 2009 | Quickie Wheelchairs Health & Beauty
My quickie aspire wont turn on
3 months is too long for gel batteries to sit off-charge, without being fully charged first, then disconnected before storage.
Your charger is trying to charge, but the batteries aren't cooperating. This chair accepts either the Group 22 or Group 24 gel-sealed batteries. 22 are about 50 amphour, and 24 are about 74 amphour, and will give you greater range. Cost for a set of two of either is going to be about $350 and $450 respectively. Ouch!
Jul 07, 2009 | Quickie Wheelchairs Quickie Aspire...
Apr 12, 2009 | Quickie Wheelchairs Quickie Aspire Power...
Health & Beauty Logo
Top The Health & Beauty Experts
widgid
Level 1 Expert
Marc Taylor
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
