My Tcl 55s401LDAA has the blue screen. Bought repair kit ( powerboats and main board) swapped them out but blue screen remains. Tcon board? If so, can't find this model tcon board anywhere. Please advise.
4 Suggested Answers
Anonymous
SOURCE:
caroldon
  • 17130 Answers
SOURCE: lg lcd can a bad tcon board kill all power
Yes , it can be a short on the board that will ask the SMPS unit to protect the power so as to switch off. So even with a multi-meter check you will be able to trace the short on the board, the drivers or any capacitor that is cutting off the power which must solve the issue.
Posted on Dec 15, 2011
Larry
  • 2800 Answers
SOURCE: yes I have an lg 55xl6500 tv when I power it on black screen unplug tcon board it lights up to a blue screen so is tcon board bad?
Are you unhooking the LVDS cable or the ribbon cables to make it go blue
Posted on Dec 13, 2017
Testimonial: "unhooking the main lead going into tcon board"
Larry
  • 2800 Answers
SOURCE: Have Vizio E60-c3 LED TV. Picture not working, Backlights on, Audio works. Ordered Complete repair kit from Shop Jimmy.
About 99% of the boards from shipjimmy are good, unfortunately lI think you have a bad panel and its destroying the tcon board, did you check the fuse on the tcon board?
Posted on Feb 21, 2018
Feb 21, 2018 | Vizio Televison & Video
Tip
I have a Proview LCD TV model # PA-32JK1A. When I plug in the TV, the orange...
This is the basic guide that can be applied to most LCD flat panel TV.
By Bud Martin
First, try unplugging it from the outlet for about an hour to see if the TV will reset itself since the minute the TV is plugged into the wall, the power supply and processor will be running 24/7 and the EPROM can get corrupted by spikes and surges. Try using good quality surge suppressor to see if it will help if it happen often.
Look for burnt brown hot spots on the circuit boards, capacitors with leaking/bulging top or seals. Loose wires and connectors. Blown fuses.
Notes: We are dealing with high voltage that can kill you! so if you are not sure what you are doing, please have it fixed by the pro that has proper tools and safety equipment. Try to use GFI outlet and isolation transformer when work around the TV set and DO NOT DEFEAT THE GROUND PIN OF THE OUTLET/POWER CORD.
1) The power supply module (There are 4 regulated output voltages:- Standby 5vdc, switched 5vdc, 12~16vdc, and 24vdc).
The power supply converts the 120/230vac 50/60Hz into DC, then the high frequency (50~100kHz) switching circuits convert it back to AC but at high frequency which allows the power supply to use smaller and much lighter weight transformers (Ferrite core instead of heavy iron core), then this high frequency AC voltage is fed to the rectifier Diodes to get the DC output and filtered by DC filter capacitors that must have low ESR (Equivalent Series Resistance), if general purpose electrolytic caps are use, they will fail within a year or less due to high ESR.
The power supply has Standby 5vdc (5VSB, this is a MUST have before anything else will work, when this voltage is not present, there will be no any indicator light on the front panel) which is always on the minute the TV is plugged into the AC outlet, so it is on 24/7 and that is why the power supply will fail even though you may use the a TV not very often. It will see all the voltage spikes and surges 24/7.
This 5vdc is used to power the Processor and the Infrared remote receiver module which will be waiting for the command from the remote control or from the power switch, when the Power on command is received, the Processor will send the turn on signal (3.3~5vdc) to the power supply module (PSON pin) to the switch on the main 5vdc for the rest of the logic and Tuner circuits, 12~16vdc for the sound amplifiers (mostly Class D amplifier for efficiency and small size) and for the T-CON board (interface board between the LCD panel, some T-CON uses 5vdc, and the Logic board), and 24vdc for the Back lights inverter board (if there is no 24vdc then no back light).
Common failures:
Blown main AC fuse due to shorted out Diodes, transistors.
Bad capacitors leaking or bulging tops:
Shorted Diodes, transistors in the DC output side.
Testing the power supply output with dummy load:
24vdc testing: Disconnect the wires that go to the inverter board first. You can use two #1157 (using both Lo & Hi filaments by paralleling them at the base) car light bulbs connected in series so they can handle the 24vdc, this will put light load (about 70w) on the 24vdc output, the voltage out should be steady at 24vdc (+/-2v), if not, the power supply has regulation problem.
12vdc testing: disconnect the 12vdc TV load from the power supply board and attach one #1157 (using just the Hi filament), the 12vdc output should stay at 12v (+/-1v), if not, the power supply has regulation problem.
You should see the lamps go on when the TV power switch is ON and go OFF when the TV is powered OFF.
2) Main Logic board (It has Processor, Tuner, Sound Processor, Sources selector, Power amplifiers for speakers, interface port to the T-CON board for pictures).
This logic board sends out the turn on signals (3.3~5vdc) to turn on the rest of the Power supply module (Switched main 5vdc, 12~16vdc, and 24vdc), Inverter backlight ON (if no back light on command then there is no back lights),
Logic board supplies 5 or 12vdc to T-CON board B+ pin through switched transistor if T-CON board does not get the voltage from the logic board, you will get white/gray glowing screen without pictures.
Back lights Dimming (PWM) control signal.
3) Back lights Inverter board. Its job is to provide the drive voltage for the CCFL (Cold Cathode Fluorescent Lamp) to give white light for the screen.
This board is fed by the switched 24vdc (VBL) from the power supply module, it also get the Back lights on (BL on) control signal and the Dimming (Dim/PWM/) signal from the logic board. So for it to work, it needs 24vdc and the BL_ON signal.
Common failures:
Blown surface mounted fuses due to shorted transistors/ICs, Transformers.
Bad capacitors.
4) The T-CON (Timing Control or LCD controller) board (on the LCD panel assembly). It transfer the universal image signal of TTL and LVDS signal to specific TFT (Thin Film Transistor) LCD.
This is the interface board that talks to the Logic board and the LCD panel to produce pictures on the screen. White/gray glowing screen when it fails or not getting the voltage from the logic board (the 5 or 12vdc is supplied by switched transistor on the logic board). Notes: T-CON board is mounted under the metal cover shield.
Common failures:
Scrambled pictures, Lines, multiple pictures, color smears/blotches, rolling pictures after warm up.
Blown surface mounted fuse.
No pictures, very dark screen almost like there is no backlights.
5) LCD panel assembly to display pictures. The LCD pixels will block or unblock the back lights from the back of the panel to the front of the panel. This is the most expensive part of the TV, it will be more than the TV is worth.
As you can see, you must have all the above Voltages and signals for the TV to work properly. This may help you narrowing down the bad modules instead of buying the wrong module just to find out later that it did not solve the problem. Hope this will help you out.
Sound problem:
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. To get the sound repair, it can be from $150 and up, so if you can put up with using the good set of Powered PC speakers which actually give better sound than the tiny speakers inside the TV, I would keep using it that way, you may want to find out if the on screen sound setup will allow you to set the audio line out to be VARIABLE which means the sound output feeding the PC speakers can be varied using the TV remote control, then all you have to do is to set the PC volume to about half way up and set the TV volume to what ever you want.
Inverter board connector: you can also see the Fuse 4A/160V
http://i.fixya.nethttp://i.fixya.net13ca788.jpg
Power supply connector:
http://i.fixya.nethttp://i.fixya.net78e0d9a.jpg
http://i.fixya.nethttp://i.fixya.net2fc510f.jpg
T-CON board: (metal cover shielding is removed to show the bd.)
http://i.fixya.nethttp://i.fixya.net0b5367e.jpg
Inverter board:
http://i.fixya.nethttp://i.fixya.netaf0a695.jpg
Logic board:
http://i.fixya.nethttp://i.fixya.net4bd108e.jpg
T-CON board is dead, no power or blown fuse on the board, screen turns WHITE, must see it in darkened room, otherwise you may mistaken it for failed backlight.
http://i.fixya.nethttp://i.fixya.net3a91b68.jpg
Bad T-CON board after warm up, you get lines, multiple pictures, strange colors blotches, etc.
http://i.fixya.nethttp://i.fixya.netd3cf194.jpg
Bad caps (leaking/bulging tops). Make sure to replace bad cap with good cap such as PANASONIC FM or FC series , they are Low ESR (Equivalent Series Resistance) which is a must for switch mode power supply, and 105c rating. Do not use generic electrolytic caps.
http://en.wikipedia.org/wiki/Capacitor_plague
http://i.fixya.nethttp://i.fixya.netbe827ec.jpg
Bad T-CON board or power supply problem
http://i.fixya.nethttp://i.fixya.net034e1db.jpg
24vdc power supply output testing using two 12vdc car lamps in series.
http://i.fixya.nethttp://i.fixya.net4f2929c.jpg
Bad LCD panel, vertical 1~2 pixel wide lines
http://i.fixya.nethttp://i.fixya.net28e50c1.jpg
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Free service manuals: www.elektrotanya.com
on Jan 09, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Samsung UN506400AFXZA NO PICTURE HAS SOUND , HAS LIGHT BLUE/GRAY LIGHT ON SCREEN REPLACED TCON BOARD NO HELP
You will need to replace your main board. This is the board that the hdmi cables plug into. Happy tv repair.
Aug 02, 2017 | Samsung Televison & Video
Need advice on color issue with Samsung UN46EH6000F TV
The TCON board or the LCD panel is Faulty , Can confirm by replacing TCON board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 04, 2017 | Samsung UN46EH6000FXZA 46 1080p 240Hz LED...
Diagnosing an LCD TV issue
No need to check anything more. Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Sometimes a reset might help
Good Luck.
Sep 12, 2016 | Sharp Televison & Video
I have a samsung LED 60" and replaced the tcon board. having the same issues
Either the t con board is no good or the issue lies within your main board.
Dec 01, 2015 | Samsung Televison & Video
I have a Proview LCD TV model # PA-32JK1A. When I plug in the TV, the orange standby light comes on like usual. When I turn on the TV (with the remote or the front panel) the blue power light will come...
Hi, I just read what you have posted on my LCD TV troubleshooting guide, it does not sound like bad T-CON board because you do not get the sound, you disconnected the main T-CON connector from the main board and get the glowing screen but you still do not hae sound.
In the LCD TV, you can discoonect the backlights inverter board power cables (cables from power supply to the backlights inverter board), and the T-CON board cables from the the main board to the T-CON, you should still get the sound since there are no feedback singals from the T-CON or from the backlights inverter boards to tell the main board that they are bad or not.
If you are 100% sure that you do not have sound on all the input modes then I would suspect the main board problem.
At least the backlights ineverter is good.
Do you get the 12v at the T-CON board surface mounted fuse?
Dec 20, 2010 | Televison & Video
There is a blue line on right side of screen extending upward about third of the way
A picture is worth a million words in this case.
Since the line is not all the way up chances are you might be able to repair it.
Might be the LCD controller, which for Vizio L37 is T370XW01 or could be the main board.
if the line was all the way it would likely have been the LCD itself, which is not repairable; chances are still that's what it is, of course, but I can't remember seeing an LCD problem as you describe it.
Both the LCD controller (also called TCon) and the main board can be found on eBay and other dedicated stores. In fact I happen to have the TCon from a recently dismantled L37...the main board went out to repair another Vizio L37 just two days ago.
Hope this information helps.
Your rating is appreciated!
Jan 29, 2010 | Vizio L37 Television
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
