Optics Logo
Herb Jacque Switzer Posted on Jan 23, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Interested in value of reconditioned model 94 saddle ring, 38/55 mfg. date 1895
Tony Parsons
Level 3:
  • Optics Master 6,405 Answers
  • Posted on Jan 23, 2020
Tony Parsons
Optics Master
Level 3:
Answers
6405
Questions
Helped
1650890
Points
20272
Sorry, no. But thanks for asking.
5 Related Answers
57 varieties
Karl Wright
  • 1653 Answers
  • Posted on Nov 10, 2009
SOURCE: My Whirlpool side-by-side model-ED20ZKXBW00 MFG
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try completely defrosting the FF as despite common belief these units are not totally frost free.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Anonymous
  • 43501 Answers
  • Posted on Jan 17, 2011
SOURCE: my older model kenmore side
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Anonymous
  • Posted on Nov 30, 2011
SOURCE: watch says 84 g1 1895,
4751947
General Systems Consulting
  • 5051 Answers
  • Posted on Mar 23, 2012
SOURCE: Where is the main smd fuse located for a dell laptop EASYNOTE Model Hera G mfg date 2009/03/19
I've never seen a laptop with a fuse!!!
gregmk
  • 204 Answers
  • Posted on Jan 13, 2015
SOURCE: Was wondering what year my winchester model 94 was made it is a 32 special with 20" barrel no saddle ring serial number is 1734771
this is from the Wikipedia web site -
Starting in 1901, the Model 1894 was also chambered in .32 Winchester Special.
Hi there..I have a model 94,3855 mfg.date 1895 (ser. no.29323 ) completely restored.was wondering rough price.
You should know what you paid for it, whatever it is. If you are enquiring about its value, however - Fixya does not do appraisals or valuations
Jan 15, 2020 • Optics
2answers
300 savage model 99. What year was it mfg. ?
You did not supply all needed information so I am just guessing this might help.
Dates of Manufacture* for:
Savage 1895/1899/99.
. Our database contains values of serial numbers through 566,000 which ended the year 1950. Serials did not strictly run sequentially. Therefore, dates may be a year different, especially near the "boundaries".
Enter the serial number (leave out the "," or ".") of your Savage 1895/1899/99 in the box below:
American Rifleman (July, 1980; page 28) contains a very different set of dates for serial numbers through 193000.
Enter the serial number (leave out the "," or ".") of your Savage 1895/1899 in the box below:
Lever Boss Codes: A = 1949
B = 1950
C = 1951
D = 1952
E = 1953
F = 1954
G = 1955
H = 1956
I = 1957
J = 1958
K = 1959
L = 1960 M = 1961
N = 1962
P = 1963
R = 1964
S = 1965
T = 1966
U = 1967
V = 1968
W = 1969
X = 1970
Dec 28, 2017 • Optics
1helpful
Can you tell me the year my Winchester Model 94 32 special was made? The serial number is 1380891. Thank-you
Mark, I'm not sure if you ever got your answer in all of that above but just in case you didn't....yours is in the war years 1944, or 45. Winchester kept no records of public serials those years because pretty much all of their manufacturing went to the war effort. Simply no record keeping. In 1942, #1221289, was sold. 43, 44, 45, 46, and 47 there were no records. In 1948 they began again at the number 1500000. You can't get any accurate to the day date on yours but if you divide those numbers by the five years you get approx 55,700 a year. So 1221289 + 55700 is approx 1277000. Add another 55700 and you get approximately late 1944 to early 45 for your rifle. I hope that helps.
Feb 29, 2016 • Optics
1helpful
What is the value of a 94 Winchester classic?
Hello, here is website of a gun that like yours that just sold and the value.$500 Winchester Model 94 Classic With 26 Octagon Barrel and Nice Wood
Please rate my answer, thk you.
Nov 17, 2015 • Optics
1895g serial number MR54007C
TRY THIS LINK
http://www.gunvaluesboard.com/marlin-serial-numbers-dates-of-manufacture-1664.html
Top Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you an Optic Expert? Answer questions, earn points and help others
