SOURCE: kenmore fridge ice maker not working
only two things this could be, either your water valve is bad or your icemaker is bad. you can get a kit which comes with both for a little over a hundred bucks, and you can change them yourself.
SOURCE: HOOK UP OF ICE MAKER TO THE WATER LINE
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
SOURCE: Ice maker not making ice after replacing water line.
Ice makers are a common problem. On many brands there is a reset button behind the plastic cover. However if you physically see Ice clogging your water inlet to the ice maker, this will without a doubt prevent the ice maker from making ice. Use hot water or a steamer to unclog the ice or you can leave the unit unplugged for a few hours to defrost the freezer. You should be able to hear when the ice maker cycles and lets in water. Note: if you're getting plenty of water out of your in door water dispenser, then it's NOT a water supply problem. You may need to check the solenoid that controls water entering the ice maker.
SOURCE: GE Fridge Not Dispensing water
First place to start is in the fridge. Look behind the crisper drawers for the water tank. It may have frozen at the outlet line. Try thawing it out with a hair dryer or a heat gun, being careful of course not to melt anything.
SOURCE: my fridge makes a loud popping noise. It does not
defrost heating coils breaking ice ( not to worry)
