Dryers Logo
Gary Legendre Posted on Jan 24, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change the cord - Dryers
Jorgie Navito
Level 3:
Master:
  • Dryers Master 357 Answers
  • Posted on Mar 28, 2020
Jorgie Navito
Dryers Master
Level 3:
Master:
Answers
357
Questions
0
Helped
108955
Points
2245
Replace cord
yes you can change it or you can also take some repair.
1helpful
Check line cord phone mean
The cord or cable connecting the phone to your pstn line is called line cord. check the connection at the back of phone and the wall jack. if it is ok change the cord and check.
My hdmi cord was is no longer able to be used and the regular cord from the ps3 wont work how do i get it to work
May be simple as changing your input on the TV. I know this is something usually over looked.
1helpful
I have a Frigidaire FAFS4473LW Steam Washer- 3 prong. I moved into a new place with a 4 prong. Do I need a 4 prong cord, or can I change the 4 prong adapter on the wall?
Hi nancy huerta...
You can change the cord or the receptical...
It will be easier to change the cord...
Purchase a four prong plug cord that will fit into your receptical, then wire your dryer for 4 wire instead of three wire use.
To see a picture and explanation of how to wire your dryer for a 4 wire plug go to the following webpage.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
My dryer's power cord has 4 prongs, my wall socket has 3 holes, can I change the power cord, or is there an adapter to change from 4 to 3 pronges.
Un screw the 2 hex screws from the back of the dryer where the cord goes in.
There will be 3 screws that connect the cord to the dryer, loosen or remove them to remove the 4 prong cord.
A hardware store will carry the 3 prong cord you need, tell them it is for a dryer.
Re-connect the 3 prong cord to the dryer.
Plug in and test after you have installed the new cord.
How do I Change outgoing message on GE -29897GE1 Corded
The manual is accessible through the GE website. Here's the direct link to the PDF download:
http://www.homeelectronics.net/ge/pc/IB/29897GE2_IB.pdf
Too many prongs on dryer power cord???
Do not just swap out the cord on the dryer. It has 4 prongs for a reason.
You will need to call a licensed electrician to change your outlet for the different service.
1helpful
II HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL.
Your issue is as follows;
"iI HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL."
A 3 prong cord should be wired as follows:
1. 1 end of cord connects to 1 outside terminal.
2. The other end of the cord connects to the remaiing outside terminal.
3. The center wire connects to the center terminal.
4. A separate ground wire should be attached from the dryer chassis, then to a metal cold water line, or an exterior grounding rod.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Top Dryers Experts
john h
