When checking for a spark you must make sure the spark plug is well earthed against the cylinder, and give the starter a good pull, if there is no spark try a new clean plug ( make sure the ignition switch is on ) if all this fails then unfortunately you may well need to fit a new ignition coil, this will be situated under the covers against the flywheel.
SOURCE: i have a petrol black
50:1
Farmerbear
Testimonial: "Thanks for the info. I've been trying to get the right mix for ages."
