A
Anonymous Posted on Jan 26, 2020
How To Reset drum of Fax L3000 canon - Canon Office Equipment & Supplies
James Ballard
Level 2:
Habit-Forming:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 38 Answers
  • Posted on Jan 27, 2020
James Ballard
Expert
Level 2:
Habit-Forming:
Night Owl:
Answers
38
Questions
Helped
12620
Points
107
All i could find was to either replace the drum or buy a new fax
Drum life warning on toshiba dp120f
reset drum Counter for DP120
Turn fax off. Hold down 0, 1, 3 on numeric key pad and turn fax on. Then release the 0, 1 & 3 and enter the number 80, wait a few seconds and should see a message confirming counter has been cleared. Then turn fax off and on again
3answers
CANON CLC 1100 ERROR CODE E079 CAN YUO HELP ME?
Have you tried to reset? maybe you can reset first meanwhile I will be looking for further solution
4helpful
Panasonic KX-FL511 fax, have replaced the drum kit twice now, following the install instructions with drum (and same instructions in manual). Machine still will not reset counter or recognize the new...
after replacement of drum when you close the the cover just wait for few seconds to reset the drum
machine will take one cycle. do not open lid before comletion of reset cycle done.
I replaced the drum in the fax machine and it still say i have only 14 copys left, how do i reset that? I have muratec fax MFX 1700
You are not supposed to replace the drum until it says"replace drum"
Not when it is saying "replace drum soon."...you have prematurely blown fuse in the cartridge so now it will not reset.
Try the following...
Press...PROGRAM,*,*,I(That is Capital I), then ENTER.(SHOULD RESET IT.)
39helpful
Brother IntelliFax-4100e Fax Reset drum counter
With the front cover still open, you should press Clear ("Replace Drum?" should appear on the display), and then 1 for Yes. Wait for "Accepted" message and close cover.
It may be necessary to remove the drum unit and put it back in, and then, with the cover open, do the a/m procedure.
1helpful
How to reset brother 2850 fax drum
Try opening the front and press clear it should say replace drum press 1 for yes it should then reset,
3helpful
5helpful
2answers
How do I reset the drum counter on a Muratec F320?
Ok, this is how I resolved it for my fax machine.
I powered down the fax, removed the new drum and reseated it.
When I powered it back on the counter reset itself as it is supposed to.
10helpful
3answers
HOW DO I RESET MY CANON FAX JX200 TO FACTORY DEFAULT
hold menu and #
press down to select clear
press Start/Copy
Trojan :)
old marine
old marine
ZJ Limited
ZJ Limited
