How to turn wireless WiFi on/off Windows 7, 8, 8.1, & 10
Description
This article describes how to turn the WiFi radio on or off. Follow the provided instructions to enable the wireless card.
There are several ways to turn the wireless radio on or off.
Applicable Brands
Operating Systems
Solution
Windows 10
If there is no Wi-Fi option present, see Unable to detect any wireless networks in range Window 7, 8 & 10.
If there is no Wi-Fi option present, follow Unable to detect any wireless networks in range. Window 7, 8 & 10.
SOURCE: fujitsu siemens laptop
press the fn key and the f2 key, the fn key should be at the bottom of your keyboard, normally on the far left side.
SOURCE: Medion Akoya Multimedia notebook - wireless capability
I believe on the medion you have there may be a switch on the front or side to turn on the wireless. That or FN key and F1.
press the fn key then i think its the f5 key but which ever f# it is it has kinda like wavy lines on it read the instruction manual too it does tellyou
SOURCE: how to turn on a wireless capability?
Right click on my computer icon then click on property then click on hardware->device manager.
Then you can see all driver list.
Make sure wifi network adapter driver is installed and enabled there.
Make sure wi fi switch on laptop is turn on.
If you need driver download from below sites.
Select your model and operating system then download wi fi driver.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_ALL_A962&os=WW1&osl=en&catid=&impid=
click on above and then click on change product then select model number.
SOURCE: where is the wireless capability key to turn on
check your manual, but sometimes its on the front, some times its an f key ie F1, F2, ect this will have to be used with the fn key press fn + F? keys together.
hope this helps
