Coffee Makers & Espresso Machines Logo
Michelle Posted on Jan 27, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My franke flair coffee machine is telling me to fill bean hopper but it’s already full. Can you help?
Attique-ur-Rehman
Level 3:
Top Expert:
  • Franke Master 2,677 Answers
  • Posted on Apr 15, 2020
Attique-ur-Rehman
Franke Master
Level 3:
Top Expert:
Answers
2677
Questions
Helped
877742
Points
8006
Https://www.youtube.com/watch?v=RcsT1SdxbdE
5 Related Answers
Anonymous
  • 29 Answers
  • Posted on Aug 15, 2007
SOURCE: Bean hopper is full, grinder is grinding...but NO COFFEE!
Sometimes the chamber between the grinder and brewer will clog up. Try: Open the grind all the way up to the highest number. Push the grind button and while grinding move the dose knob (the one with the + - sign toward minus. If it does not kick in and dose try it again. If it does take off then leave it on the high number for 3 coffees. Then while the grinder is turning move the two knobs back to whre they were. If this does not work you can reomve the brew unit and right above where it sits in the machine there is a trap door that you can open. Open it and shove someting like a straw up toward the grinder and you should get a bunch of grounds droppiing down. Then try the above procedure a couple more times. If this does not work you may need to google "Saeco repair" and send it to an authorized repair center.
Anonymous
  • 4 Answers
  • Posted on Mar 21, 2009
SOURCE: Franke coffee system, always same error message ''fill water tank''
What you would have to do is take the side panel off to get at the solenoid. It is probably sticking closed and not letting the water fill into the boiler.
Anonymous
  • 1089 Answers
  • Posted on Oct 20, 2009
SOURCE: gaggia titanium coffee beans empty
Hi
If the big knob in the bean hopper is on a small #, that could be your problem. try opening the knob to the largest # and try again. If it clears and makes a cup, then on the next cup, while the grinder is operating turn the knob down again, but to a larger # than you had before. Grounds can get compacted in the chamber and prevent new grounds from entering. That is why it grinds but doesn't make a coffee. If that doesn't help, try opening the door above the brew unit funnel when the brew units is out. It should pull down on a hinge. This is the clicking you hear when you make a coffee.
Anonymous
  • Posted on Jan 25, 2010
SOURCE: Saeco Incanto S-Class Sirius coffee machine not sensing beans.
I have had the same problem the only way I could get it to brew would to use the program quantity feature every time. I was going to take it in today and decided to restore the factory settings and now its working like it should. This seems to be a circuit board issue Ouch! I have another issue with the steam, if I take the knob off it works if I don't it doesn't glad I bought a 2K model GRRRRR!
Anonymous
  • Posted on Jan 31, 2011
SOURCE: No coffee brewing with beans, but with coffee brewing with ground coffee.
make sure you use very dry non-oily coffee beans
1helpful
Bean hopper is full, machine starts to grind the coffee but right before it starts to pull the shot, it stops & says "add beans to hopper".
the add beans to hopper signal most likely is triggered by the machine not sensing enough load put on the grinder (hence it thinks its out of beans) , this most likely is set by the grind (fine/course ) id say the grind is set to an improper size and the automatic sensor is picking up on that
another thing is the coffee / if its way too moist and not dry enough then its also going to trip the sensor as well
1helpful
How to remove the lid on a franke flair coffee machine
If you are refering to the main cover! firstly the hoppers have to be removed. then the metal plate on the top(cup warmer) secured with 4 x t15 torx screws. once the plate is removed the main cover is secured with 4 oval headed screws 2 of them located under the plate just removed. the other 2 are located under the adjustment rings for the grinders. the main cover then can be removed. there are 2 electrical connection plugs that have to be disconnected .
How to fix, "no bean light" stays on?
hi there,
have you also cleaned the output of the grinder and the doser?
You have to open it (carefully) by hand, as it is normally closed and only opens when the actuator is switched on, and clean the inside with a soft brush.
After cleaning the grinder, its outlet and the doser, the machine will have to gring at least twice ti fill-in these parts, each time saying that there are no beans. It should be OK with the 2nd our 3rd cycle of grinding.
Hope that helps,
M.
Why Coffee Machine keeps saying 'fill coffee beans' ?
Unplug it to disconnect the electrical power.
Reconnect it.
Look for a "sensor" that determines when the hopper is filled -- is that "gummed-up" or "jammed" ?
1helpful
The coffee is filled and yet when it begins to grin the beans it stops and tells me to add coffee. So I giggle around the coffee dispenser and sometimes it works, but the problem is getting worse. Seems...
Are the beans very oily? Oily beans can sometimes cause things like this. My suggestion is you take out the bean hopper and clean the beans under that because on my Miele CVA4066 there are usually more than a few beans and chipped off pieces of beans under the hopper which cause some trouble.
2helpful
Saeco Vienna is full of beans but the bean light stays on
the sensor may be stuck that tells the majer there are beens in it ..look in hopper feel around!
Top Franke Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
john h
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
