The most possible scenario is that there is a dry joint somewhere between the video input female rca connector and the tv board's main signal processor, and a technician's assistance would be a good solution for the problem. Attached here below is a link to your tv model operation manual download. Please go through it and see if it works, if it fails, consider changing the entire main board.
https://manualsbrain.com/en/manuals/796083/download/
SOURCE: AV Cable Problems for PS3
I am not completely sure that this will help you, however try doing a "factory reset".
You accomplish this by first (1) having the PS3 being off (2) hold down the power button on the front of the PS3. It will beep once when you turn it on and then a second time. When you hear it the second time, let go. See what happens.
Sometimes if you connect your consoles video a different way such as S-Video, Component or HDMI, your console remembers those settings and saves them causing many individuals to turn their console on and there is no video.
I hope this gives you somewhere to start.
SOURCE: Xbox 360 not sending audio/video signal.
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
SOURCE: Hi i have an alba
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
SOURCE: I have an LG TV
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
